05-28-2008
Originally Posted by craigtoo
Well.. I went 1/2 because it's always in the hand.. constantly being adjusted... larger diameter is easier on the hand... but that also drives up the cost of the hardware... I don't think I'll go below 7/16 on that one...
Gotta go with the Dog on this one, Craig.. going with that heavy a line on the traveller is just going to be overkill. If the traveller is set up with good blocks, enough parts and a good lead to the user, 3/8" is a big as you should need to go. I get your point about the hand of a larger line, but the added bulk & volume of line and expense of the gear really doesn't make sense to me.
While the traveller is, as you say, adjusted often it's rarely held under load longer than it takes to adjust and recleat it. Focus on a good design/layout and you should be fine with lighter line (and happier in the long run).
EDIT: wrote this without seeing the end of the dialogue... sorry!
1984 Fast/Nicholson 345
