Blogs
User Name
  #51 (permalink)
Old 07-06-2008
craigtoo's Avatar
craigtoo craigtoo is offline
Barkeep - Sailor's Pub
craigtoo will become famous soon enoughcraigtoo will become famous soon enough
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
Hmmm.. that didn't work...
EDIT: ok.. THIS SHOULD WORK.. EDIT
AFTER
-C2
1987 Sabre 34 "Saoirse"
Meet me at the PUB
To get more out of Sailnet see the link in uspirate's signature....NEXT!
I love Jennifer Nettles....
  #52 (permalink)
Old 07-06-2008
craigtoo's Avatar
Deleted.. See Above
-C2
Meet me at the PUB
  #53 (permalink)
Old 07-06-2008
craigtoo's Avatar
DELETED SEE ABOVE PICS TECHNICAL PROBLEMS..
THANKS artbyjody
-C2
Meet me at the PUB
Sponsored Ad
  #54 (permalink)
Old 07-06-2008
artbyjody's Avatar
artbyjody artbyjody is offline
artbyjody is just really niceartbyjody is just really niceartbyjody is just really niceartbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Originally Posted by craigtoo View Post
Holy can't post a photo batman!
Go to...
w w w. c r a i g h a r b a u e r . c o m
Check out the link called " Rigging"
You'll figure it out from there...
craig
(apparently I've lost my computer skills over the weekend...)
goto tinyurl.com - and use that link it generates (its free btw)...
-- Jody
S/V "Hello Gorgeous" - 1983, Barberis Show 38! or Facebook me.
  #55 (permalink)
Old 07-06-2008
craigtoo's Avatar
You are the MAN!
Thanks... fixing now
-C2
Meet me at the PUB
  #56 (permalink)
Old 07-06-2008
craigtoo's Avatar
Ok..
Description of what I did.
Halyards - T900 - With mast base blocks (Gui inspired...) I'll need 2 more halyards in phase 2. One for Chute one for Second Jib.
Cunningham, Outhaul, Reef 1, Vang all led to sexy (Gui inspired) mast base blocks and through ....
deck organizers which needed custom fit teak blocks to so that they were mounted flat (deck is curved in that area...I felt like I was fitting a bridge to a violin top.... I used a dremel tool to get the fit right.. took a better part of a day...) lines then led aft to...
Lewmar Line Clutches (now installed in the proper direction) DOH! Yes... i installed them backwards... who'da thunk that the handles would open the wrong way!!
The mainsail controls:
Harken track 1.8m (Longer than stock you can see the overhang)
New 6:1 main sheet blocks with cam cleat
New 4:1 traveler (I went 3/8ths the hardware got stupid expensive for bigger stuff...but I like it...)
New boom kicker.
Everything but line clutches is Harken.
Won the first race after the rebuild... ! I do have issues... (Lessons learned to follow...)
-C2
Meet me at the PUB
  #57 (permalink)
Old 07-06-2008
craigtoo's Avatar
Some tips/lessons learned
1) Lewmar clutches are backwards....when you open them up there's a little picture of a winch with an arrow. No.. they didn't make a mistake. The winch actually goes there. Moron.
2) Drill oversize holes for all through deck attachments... this is so you can get the epoxy smeared on the exposed deck core. I could have done a better job on this. I'll be re-doing some of my mast base blocks for this reason. I'm losing sleep thinking that I scraped off epoxy as I put the bolt in ... even though I let it dry it was a tight fit...
3) Use 60min epoxy not the 5min stuff. It's "thinner" and really allows you to smear it all over the exposed core better... LOOK FROM THE INSIDE OF THE BOAT OUT AT SUNLIGHT to verify that you've completely coated the core. I was lucky and happened to look up and saw that every hole that I had already epoxied wasn't complete. Went back in and re-smeared.
4) To cover the holes left in the deck by hardware you don't need anymore do what Halekai says...use the finishing washer. Looks great and it's easy.
5) Get Butyl Tape...I was pulling off 20 year old deck organizers and the stuff still looked like Melted Pizza Cheese - Never Leaked. I'll be re- seating with Butyl this winter. I couldn't find it locally and I didn't plan in advance enough to order it online. I used another adhesive which I won't mention. It wasn't 5200 (Is that the super strong one from 3M?) but.. it wasn't the 4200 either...(The one I should have used... DOH!) Hello Winter Project...
6) I put a "Lanacote" barrier (like a grease) between all Aluminum and Stainless interfaces. (Bolts to hardware) ... I hope that's a good idea...
7) I would probably move my mast base blocks used for the sail trim (outhaul, reefs, cunningham etc.) closer to the mast - towards the bow. I placed them directly under where the line exits the boom, but they interfere now (somewhat and nothing bad at all) with the boom kicker when you're on a run. It doesn't look as neat.
8) You can talk Westmarine into an amazing discount... I beat every online price by 10% (and I'm talking shopping cart prices not MAP).... just brought the printouts with me and I had *everything* in less than 24 hours. (I think I had 1 special order which they FedEx'd for me from SanFran on their nickel.) No, the service wasn't amazing... the staff wasn't super knowledgeable... but I felt as if I got a good deal. (This was in Annapolis...)
9) Definitely start a running rigging rebuild with the end in mind. Plan Plan Plan... If you just start moving stuff around and mounting hardware you'll have a disaster on your hands in no time.
10) Boom Vangs are not to be attached to Through bolted U-Bolts on deck. While this may look very sexy and keep the vang block low so that sending the line to the organizer is easy.... it will bend. Yep. Bend. If you look in the after pic above you'll see the u-bolt in the middle of the mast base blocks with the small teak shim block (for angle). It is bent..... And now the vang is attached to a bail at the base of the mast... which meant I had to raise my kicker... crap... bunch of extra work there...
11) Blocks inside a boom are crap. crap. crap. Apparently, I had a 4:1 outhaul and didn't know it. The blocks in the boom were so worn (probably from lack of maintenance.. because THEY WERE IN THE FREAKING BOOM....) I never even noticed the advantage... I had to use a winch to move the sail. So the new design has a tiny wire block attached to the clue and my wire exits the boom on the sheave and goes through the block and is attached to the end of the boom. It's neat and clean and serviceable. It was a nightmare trying to fish the new outhaul lines through because the stupid blocks kept getting in the way...
12) Sailkote is great
As I think of more.. I'll post.
Thanks again to all...
craig
-C2
Meet me at the PUB
  #58 (permalink)
Old 07-06-2008
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
Craigtoo-
Umm...did you think that every one else might be backwards and Lewmars are correct.
If you're new to the Sailnet Forums... please read this POST.
  #59 (permalink)
Old 07-06-2008
craigtoo's Avatar
Well... that's what took me the longest!
I had to unscrew the Lewmars have my dad hold them in the air... and COMPLETELY rotate the boat beneath them... Getting the holes to line up was an absolute PITA...
-C2
Meet me at the PUB
  #60 (permalink)
Old 07-06-2008
craigtoo's Avatar
(oh.. and why is the LEWMAR label upside down when you mount them "as the directions indicate...?????)
No kidding...
-C2
Meet me at the PUB
vB code is On
Redesigning Running Rigging for a Redwing dennisvetter Gear & Maintenance 3 04-26-2007 09:23 PM
Standing Rigging Basics Mark Matthews Racing Articles 0 08-29-2004 09:00 PM
Running rigging in colors? Jonathan316 Gear & Maintenance 8 05-01-2004 10:13 PM
Replacing Your Standing Rigging Mark Matthews Gear and Maintenance Articles 0 12-15-2002 08:00 PM
Running Backstays Dan Dickison Gear and Maintenance Articles 0 05-14-2002 09:00 PM
Page generated in 0.7519 seconds (70.37% PHP - 29.63% MySQL) with 16 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
