Old 05-24-2008
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
Why is there white residue on my deck?
My boat is form 79 and the deck is white. When I walk on it I get a white residue on my sneakers or when I sit on it I get a light white residue. What is going on with the deck and how do I remedy it. I think it is original and has not been painted. Thanks!
Old 05-24-2008
ANTHRAX!!!!!!!!!!!!
ANTHRAX!!!!!!!!!!!!!
ANTHRAX!!!!!!!!!!!!!!!!!
Not really, just kidding you.... it's just that the sun has over the years decomposed the gel coat, so it starts to exfoliate...happens a lot to older boats...
Time for some paint or some new protective layer......it's just life..things get old....there is nothing you can do other than cover with new material..it will get worse...
And sometimes new material will not adhere well either...
Old 05-25-2008
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
If its not too bad, you can wax it first(use a three step process). I would try that before you paint. Can't tell without seeing it, hard to tell if you have anything left to wax.
Heres a link to a good thread on it.
http://www.sailnet.com/forums/gear-m...tml#post117075
There are also good threads on what type of polisher to use for applying a three step process. Not fun by hand. I use a Makita.
Here it is:
http://www.sailnet.com/forums/gear-m...-poliglow.html
Or it could be anthrax.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 05-25-2008
Saurav-
Stop doing so much coke on the boat...
Chances are very good that it is just the gelcoat chalking up. You need to polish and wax it.
Old 05-25-2008
saurav16's Avatar
Thanks for your help, I guess woody wax will do the trick. Thanks!
Old 05-25-2008
Rockter will become famous soon enough
Try jet-washing, with the jet set to a fan pattern.
Works wonders with teak.
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
