Old 05-25-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
Bulkhead replacement
Landlocked Sailor Looking For A Salt Breeze
Installed new marine plywood stringers and bulkheads. I intentionally left 1.5" gaps in stress areas rather than glass in. Considering using a spray foam for these areas. Not an issue of support, only to fill gaps. Any pros or cons would be appreciated
Tom Morris
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 05-25-2008
Unclear what you mean by your gaps... gaps in tabbing? gaps between hull and stringer/bulkhead edges?
Pictures would help..
1984 Fast/Nicholson 345
Old 05-25-2008
bulkhead and strnger
Old 05-25-2008
Unless you're using a rigid foam to "soften" the bulkead edge when you're tabbing, I don't see the point of these gaps... seems to me the more rigid the entire structure is the better off you are. Limber holes for drainage are fine, but wholesale gaps? I don't get it....
Old 05-25-2008
Faster-
You don't want the plywood of the bulkhead touching the hull, since that will cause a hinge point for the hull to flex and fatigue at.
Landlock-
Don't use a spray foam. Use a high-quality, fairly high density, polyurethane foam, either dinvylcell or airex. Then glass over the foam to tab in the bulkhead.
Old 05-26-2008
Faster-
SD - that's what I was alluding to when I mentioned the rigid foam to "soften" the bulkhead edges... I'm familiar with that technique.
I get the impression that Landlocked has deliberately left large gaps here and there, tabbing in between and now wanting to fill the "gaps" with some spray foam... without pics it's hard to imagine just what's up.
Old 05-26-2008
My guess is that he used some sort of foam when he did the initial tabbing and glassed the bulkhead in place, but didn't lay down a complete strip of foam between the bulkhead and the hull.
SPRAY FOAM is not an appropriate material to use, since it has very little resistance to absorbing water, and almost no strength.
Old 05-26-2008
Bulkhead
Thanks for the corrections.
I will use the rigid foam and tab to the fiberglass. I was apprenhensive of bringing the wood flush with the glass given the possible flex and grinding. Though the edges of the wood have West on them, I felt a gap of 1/2" would prevent.
Thanks
Tom
Old 05-26-2008
De nada... BTW, if you cut the foam into a trapezoidal shape, it will help you with the tabbing...since fiberglass doesn't do tight corners well.
_
/_\
The foam will help create a fillet for the glass to adhere to.
Old 05-26-2008
Bulkhead
Ok, that make sense. As you see I added a picture of the o'day 22 as it sat in Missouri. Now that I know how to upload, will do a better job when having a question. Pictures as the gentleman shared would help !
Tom
Eliminating my Bulkhead soulesailor Gear & Maintenance 12 01-18-2008 04:44 PM
Rotting Bulkhead - AGGGHHHH Finallybuyingaboat Gear & Maintenance 28 11-05-2007 10:08 AM
Bulkhead replacement, how -to landlockvasailor O'Day 3 09-13-2007 10:31 PM
Goodbye bed, hello storage GoodOldBoat Gear and Maintenance Articles 0 05-14-2007 08:20 AM
Rot in Bulkhead C&C Invader 36 (Frigate) GregGreason Gear & Maintenance 3 04-22-2007 04:15 PM
