-   -   Raymarine Autopilot Remotes (http://www.sailnet.com/forums/gear-maintenance/43534-raymarine-autopilot-remotes.html)
andy_smith 05-26-2008 03:37 AM
Does Anyone out there use a wireless remote with their Raymarine autopilot. I'm looking for feedback or reports as to their effectiveness and reliability.
Thanks,
Andy Smith
'SKYE WATER'
Zanshin 05-26-2008 05:18 AM
I have the little S100 and love it, I can press a button to change course without getting up, or sit for'ard under engine and steer my way through a passage (haven't done that in any difficult ones) and if I were to fall overboard it would turn off the autopilot and perhaps I could swim back to the boat.
sailingdog 05-26-2008 06:51 AM
I have the bigger smart autopilot controller...and it's worth every penny. Lets me see the instrument readings as well as steer from anywhere on the boat.
Zanshin is wrong about it turning off the autopilot if you fall overboard... although, if you were quick enough, you could do it manually.
Zanshin 05-26-2008 08:11 AM
Sailingdog: You are correct! I am certain that, when I bought it, I read that the receiver would go to standby mode if the transmitter loses signal to the base station; but I've just downloaded the manual and it makes no mention of that. It does state that the unit goes into standby mode after 5 minutes to conserve batteries and that wouldn't be compatible with the assumption I had. D****it, the MOB function was the only reason I got the little remote. Perhaps I can re-sell it on eBay.
trantor12020 05-26-2008 08:33 AM
If you fall over board, why won't you steer the boat back to pick you ?
sailingdog 05-26-2008 08:36 AM
Umm...the remote has a range of about 30-40'... unless you can swim like a dolphin, chances are the remote isn't going to have the range to turn the boat after your ass hits the water.
Zanshin 05-26-2008 09:36 AM
The S100 isn't waterproof, either.
I overreacted when I realized that it wouldn't turn off the autopilot. I already know that this function would only have worked in light conditions and when beating anway, conditions in which it would be unlikely that I would get anywhere close to falling overboard, anyway.
I do like the little device. At first I plugged in the little cigarette-box sized received into the daisy-chain of devices in my instrument pod, but that put it within a couple of inches of my compass. The only other position that I could find where I could plug it in was below decks, which made the signal weak.
sailingdog 05-26-2008 09:39 AM
Zanshin-
Have you even read the manual? You haven't said one thing right about the unit so far. From the Raymarine website:
Compact and lightweight, the S100 remote delivers the freedom of wireless control to any Raymarine SeaTalkŪ autopilot. The bright display is easy to read with two lines of text and a graphical autopilot mode indicator. The 5 button ergonomic keypad and intuitive menu structure provides simple operation and easy access to extended features. Rugged and waterproof the S100 fits in your pocket or clips to your belt, keeping full function autopilot control always within reach.
negrini 05-26-2008 05:37 PM
Again, Raymarine is missing the chance to publish a good manual and/or update their product. I had the bigger remote for 2 years, and loved it, not only as a remote, but as the best protable repeater I've had. Cosider I have lots of kids on board ! Well, my point is, when you get out of range the autopilot disengage itself, leaving your boat out of control. With a lot of lucky, you may manage to get back on board, if sailing, when sails colapses. If you were motoring, that would be an insane temptative. The problem comes because you're not allowed to select your remote as slave/master, so when you run out of battery (happens to me a lot!!) the core-pack should sound an alarm and give you plenty of time to gain back the control (if you had set your remote as master, only). Several times, I got caught by surprise with the autopilot disengaging suddenly as the remote died, but fortunately without damage (except for a kid knee knock a year ago). Raymarine responded to me that slave/master would be a good idea, and I'm not alone complaining about product behaviour, but they cannot say when/if it will be updated. OK, in summary, I loved that and certaily will have it on my next boat, and hopefully Raymarine can fix that .....
Maine Sail 05-26-2008 08:55 PM
Fwiw..
For what it's worth I hated mine, spoke with Raymarine and was told they had no fix for my issue so I returned it.
When I turn on the remote I have made a choice to have it on and in STBY mode or AUTO. I DID NOT LIKE THE FACT THAT THESE UNITS TURN OFF AFTER A FEW MINUTES if you are not in AUTO mode!!! Turning it back on required the remote "finding" the base, and syncing with it, which could sometimes take 45 seconds or more. It was a ROYAL pain in the ASS!!
I sail where there are lots of lobster pots and this remote SUCKED for this type of application where I would often put it in STBY for a few minutes to sail through a thick area, then I would want to hit the button, to resume AUTO mode the unit had turned its self OFF thus requiring a re-boot!!
Hey Raymarine how about adding user programmable "auto off" parameters with intervals up to at least 60 minutes!!! You've had numerous complaints about this now learn to listen to your customers and FIX IT!!!!!!
