05-27-2008
This is the NMEA 2000 color scheme, and I have annotated the typical colors used as alternates or as NMEA 0813 standard, but NMEA 2000 scheme is which should probably be used especially if upgrading to later:
White: Net-H, “high” data signal (yellow maybe used by nmea 0183)
Blue: Net-L, “low” data signal (brown maybe used by nmea 0183)
Bare: shield (also seen as silver)
Red: Net-S, 12v DC power supply
Black: Net-C, 12v DC ground
Hope that helps, I do not think there is a special color for the in and outs but if you prefer you can use the data signal colors and use a wire with a colored stripe in them...
Example Garmin GPS 126 wiring (note different uses of color - nmea 0183)
Pin Colour Function
1 Red 10 - 40 volts DC
2 Black Ground
3 Blue NMEA Out Goes to Yellow ( this is the only cable you need to connect to the radio.)
4 Brown NMEA in
5 White No connection
6 Green No Connection
7 Yellow Alarm Low
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
