Old 05-27-2008
badsanta is on a distinguished road
Raymarine ST60
My St60 wind gauge is acting up. It measures speed well and the cups spin, But the wind direction is erratic and never seems to stabilize.
When I look at the unit on the mast, you can see the wind pointer, but it just spins around back and fourth. Any thoughts. Many thanks Al
Old 05-27-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Has a bit fallen off the weather vane? My old ST50 looked like its tail had been assaulted by seagulls (actually, UV damage).
Eventually a raising bridge took it (and paid for the replacement.)
Jonathan-Livingston
Old 05-27-2008
boydgatlin's Avatar
boydgatlin is on a distinguished road
Just went through similar problem with my ST60. You might first check the set screw where the vane sits on the shaft of the sending unit, as well as the connections to the display. But...chances are your final solution will be the same as mine---replacing the sensor unit at the masthead.
Old 05-27-2008
Thanks, That gives me a place to start. Now I have to get my butt up that mast!! Al
Old 04-02-2009
gardadams is on a distinguished road
The vane on my wind indicator broke. The rest of the unit is functioning well. Has anybody who has replaced their masthead unit saved old parts? I would like to buy the vane. Thanks!
Old 04-02-2009
cnc33voodoo's Avatar
cap'n chronic
cnc33voodoo is on a distinguished road
you can buy one from raymarine and if you want to cheap out order a rotovecta unit but have fun calibrating it.
I have an st40 with the rotavecta and it was nasty to calibrate but works perfect now.
what exactly happened to it? i know of a shop that repairs these units.
c&c 33 tall rig
Old 04-02-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Al,
Check you PMs. If you want I'll be down on St. george is. this weekend, could lend a hand sunday afternoon if you want.
Merit 25 # 764 "Audrey"
ST60 Multi NMEA Interface dave8976 Gear & Maintenance 20 07-23-2010 04:14 PM
Raymarine Autohelm ST1000 Problems And Raymarine Warranty petertribo Gear & Maintenance 9 07-27-2008 09:36 PM
New York-listed Garmin is mystery bidder for Raymarine marinedtcomRob Gear & Maintenance 33 05-27-2008 01:10 PM
Raymarine ST60 johnbarry General Discussion (sailing related) 2 11-07-2005 01:43 AM
Raymarine ST60 Rotavecta johnbarry Gear & Maintenance 0 11-03-2005 06:24 AM
