05-27-2008
It can handle the Bluechart software, with serious limitations, but is not compatible AFAIK with the Bluechart G2 series.
BTW, if you have the BlueChart software loaded on the computer, it will allow the computer to act as a Chartplotter IIRC. However, using the NOAA charts and SeaClear II is a lot cheaper and the charts are probably more up to date.
If you don't have an RS-232 serial port on your computer, you will need a USB-to-Serial port converter cable.
