Old 05-27-2008
Finallybuyingaboat's Avatar
Finallybuyingaboat is on a distinguished road
Outboard - Drain plug will not unscrew
Okay, I almost have my barge ready to have a mast attached. I got the boat into the water today and it didn't sink! I have done major work on this mess over the past 7 months and still did not know if it would sink or float until today, so I am extremely relieved! I'll post some pictures tonight or tomorrow night.
Anyway, I need to replace the gear lube on the lower housing of my outboard, but I cannot get either the vent plug or the drain plug to turn at all. I do not want to strip the srcew heads, so once again I have come here for some ideas...it is an 8 HP evinrude yachtwin long shaft motor. So far, I have just been trying to turn it with a large flat head screwdriver, but it accomplishes nothing.
I bought the motor second hand, so have no idea when the lube/gearcase oil was last changed, so I figure I should do it just to be safe. It should be changed every year anyway.
Old 05-27-2008
lbdavis's Avatar
lbdavis is on a distinguished road
I've had a tough time with lower unit screws in the past and I always got them with the largest flat head screwdriver I could find and a second person on the opposite side of the lower unit. This way I could apply my full force down (or in this case, sideways ) onto the screw head without trying to break the engine free off the motor mount.
Be sure your helper is safe from impalement from said screwdriver!
Old 05-27-2008
pfatyol's Avatar
Swansea, MA
pfatyol is on a distinguished road
Do you have an impact driver?
I have had luck with PB blaster then using the impact driver.
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
Old 05-27-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
This may sound archaic, but have you ever tried using a screwdriver bit in a bit & brace? These tools may have been ignored during the past decades, but I still find uses for them every now and then.
You can apply more downward pressure because of the ball-bearing palm knob on axis with the screw, reducing the possibility of stripping a screwhead while maintaining increased torque.
True Blue . . .
sold the Nauticat
Old 05-27-2008
TrueBlue's Avatar
Señor Member
I would caution you against using an impact driver against the thin aluminum casing of your outboard's lower unit. These tools require a heavy blow in order to work effectively - with risk of cracking the casting.
True Blue . . .
sold the Nauticat
Old 05-27-2008
timebandit's Avatar
timebandit is on a distinguished road
Do yourself a favor and use a properly sized and dressed screwdriver.
You might try turning it in a tightening motion first.
Screwdrivers of the proper size usually have a square shank so you can use a Cresent wrench on them. Try to keep the wrench as close to the bit as you can.
I also advise against the impact screwdriver.
If you ruin the slot and mangle the plug beyoud all repair it is time to use the Small hammer and punch.
Rick
Old 05-27-2008
I'll go fo rthe biggest screwdriver I can fit in , and if that does not work I will try and find an old manual drill as trueblue put forth.
Old 05-27-2008
SVDistantStar's Avatar
'72 Pearson 36
SVDistantStar is on a distinguished road
Send a message via AIM to SVDistantStar
I do small outboard repair and when i have plugs that wont move ive got a special screw driver. Its a large flathead thats been ground down a bit to not be as pointed. It has a square shaft so i can get a wrench on it. I lay the motor on the ground with the plugs up, spray them with either PB Blaster or Seafoam spray. I then push as hard as i can on the screw driver wile turning the wrench. It works about 99.9% of the time. If it doesnt work, ill pull the lower unit apart and soak the whole thing in a bucket of WD-40.
1972 Pearson 36 S.V. Distant Star
Parts for sink drain overholtzer S2 1 09-07-2007 04:07 PM
Source for Oil drain plug bestfriend Gear & Maintenance 6 01-25-2007 06:40 PM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
Bilge Drain Plug in a Sailboat AJS Gear & Maintenance 3 10-23-2002 08:18 PM
