Old 05-27-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
Tef-Gel alternatives?
Sauntered down to the local chandlery for some tef-gel. Re-attaching various hardware to the mast. They'd never heard of it. Went next door to West, they'd never heard of it. Went to the West Marine website, not listed.
Searched the web for the maker of Tef-gel. They have a dealer locator. Only once place listed fo all of Michigan, a spar retailer. Called them and they are only listed with the manufacturer because they buy the stuff for their own use. The helpful person did offer to send me 2 tubes anyway. She was suprised nobody local carried it.
Is it available off the shelf near you?
What would you use as an alternative?
Old 05-27-2008
LanoCote or Anhydrous Lanolin work quite well as a substitute. The first you can get at most chandleries, including WM. The second you can get at many pharmacies or drug stores.
Old 05-27-2008
EO32's Avatar
EO32 is on a distinguished road
We've got a great store called fisheries supply, that's where I've been spending all of my boat money.
Marine Supplies from Fisheries Supply - Everything for the Boat Owner
I've only used Tef-gel, but I think Duralac may do the same thing.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 05-27-2008
EO32-
Yup...Duralac is basically designed for same purpose as tefgel.
Old 05-28-2008
Hunter 26
sharkdive1 is on a distinguished road
Xort, that is kind of funny that West Marine does not have it, because all of the West stores here in South Florida do. They also have it in just about every marine store around. It is also made down here, that maybe way.
Old 05-28-2008
knothead's Avatar
Maybe because corrosion is such an important issue in FL products like that sell well.
BTW, the company that makes Tef-Gel also makes what they call Tuff-Gel.
I've been using it for awhile now and had to remove some screws that I had applied it on a few months ago yesterday. Not a real long term test but I was pleased with it's performance.
The screws were not as tight as they would have been with red Lok-Tite but certainly wouldn't have vibrated loose and there was no visible corrosion on or around the threads.
I just buy the stuff online from their website.
Ron Paul 2012
"wikijar"
Old 05-28-2008
jjablonowski's Avatar
jjablonowski is on a distinguished road
I got mine through Defender Industries in Connecticut, mail-order.
Old 05-28-2008
Maine Sail's Avatar
I've actually tried..
I've actually tried to find a replacement for Tef-Gel but have yet to find anything as thick or that works as well. I used Lanocote for years but still had issues with stainless & aluminum. Tef-Gel is the only product I've found that actually works as intended.
I've probably purchased 20 products, from different industries, hoping to find an alternative to Tef-Gel and still have not found anything that even comes close. The stuff is very uniques and it works!
It's worth it to mail order and one syringe will last you a while as a little bit goes a long way!! I'm on season 3 with the last 1oz syringe I bought..
Tef-Gel 1oz syringe $11.95
______
-Maine Sail / CS-36T
Old 05-28-2008
boydgatlin's Avatar
boydgatlin is on a distinguished road
Jamestown Distributors ( Boat Building and Woodworking Supplies ) is a source for Tef-Gel.
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 15 04-25-2008 03:56 PM
AGM or GEL batteries? Kater Gear & Maintenance 19 03-12-2008 12:50 PM
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
Lead acid, agm, or gel batteries? aroundtheworld Gear & Maintenance 5 03-26-2006 07:57 PM
Gel coat vs epoxy for hull dpoperngr Gear & Maintenance 6 10-28-2002 11:48 PM
