Old 05-27-2008
Stu01 is on a distinguished road
Reefing Question
Hello All,
I have had no experience with reefing a mainsail. I have read and seen diagrams on it and was wondering about one aspect of it where the cringel (clew) line come back to a block on the boom near the gooseneck and then down to a cleat on the mast. Doesn't the line that travels from the boom to the cleat on the mast restrict the travel of the boom? It would seem so to me. Or should the boom travel be naturally limited since you want to be close-hauled?
Anyway thanks in advance for you input.
I think this may be my 10th post so now I can PM USPIRATE for a higher resolution picture of his deckhand.
Stu
Old 05-27-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
Lines from the boom are rarely cleated on the mast for the very reason you have noticed. It is probably rigged wrong.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 05-27-2008
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
Lines that come off of the boom at the mast are at the pivot point and don't restrict the movement of the boom. if it was farther out it would start to restrict. I hope this helps and i have understood your question?
Old 05-27-2008
Stu-
Might be worth mentioning what boat you have, since this may be normal for your boat.
Old 05-27-2008
Alas, I own no boat. I do sail as member of a sailing club here is San Diego. I have taken a shine to the PSC Dana 24 however, and I was looking at a rigging quide that shows, for single handed set-up, the reef lines coming off the boom, down to a block at the mast step and then back to the cockpit. In reviewing the diagram, it (the cringle line) does show the non single handed setup as cleating to the boom. The cunningham line does cleat at the mast, but I understand that this should not interfere with boom travel.
reef diagr on Flickr - Photo Sharing!
Hopefully the link works and is clear enough to show the single-hand setup from the boom to block at mast step.
Thank you.
Stu
Old 05-27-2008
I'd rather be sailing
labatt will become famous soon enough
Let's see if I can get this post in before SD
They are talking about two different methods of reefing. Method #1, what you refer to as "non single handed setup", goes from a tie down on the boom, up through a grommet in the leech of the sail, down to a turning block on the boom, forward to a cleat. There will be a hook on the boom, and you will lower the main to the first reef point, put the hook in the cringle on the main to secure the luff of the sail. You then pull in on the leech reef line. The leech reef line acts as a replacement outhaul and also effectively creates a new sail foot.
The other reef method - referred to by you as "Single handed set-up", runs the leech reef line back to the cockpit. An additional form of this replaces the hook on the boom with a pre-run line through the first reef cringle on the luff of the sail, through a block at the base of the mast and back to the cockpit. With this method you can reef both the leech and the luff without having to go forward (which is how my boat is set up).
A third type is single line reefing, which is fine for smaller boats but gets worse (with friction) as boat size increases. This method runs a line all the way from the leech reef point forward through the luff reef point and down, then back to the cockpit. You pull on one line and you get a reef. It's a long line making many turns, so I'm sure you can see how friction can get nasty.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 05-27-2008
Labatt's descriptions are pretty good... the first is for at the mast slab/jiffy reefing. The second is for two-line reefing at the cockpit, the third is for a single line reefing system. However, of the two latter systems, two-line reefing is much better, since it gives you much more control over the sail shape by having separate reefing tack and clew controls.
Yet another reefing line question saltypat Gear & Maintenance 7 11-06-2007 03:32 PM
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 07:00 PM
