Baby Stay setup, how does this one work? - Page 2 - SailNet Community
post #11 of 14 Old 05-28-2008
CaptKermie's Avatar
BabyStays for Trailerables
Most trailerable sailboats have a set of baby stays that attach to a hound about 6-7 feet off the deck and to the stantion bases at the beam. The same hound is used with a winch attached to raise and lower the mast, the baby stays keep the mast from swinging too far to port or starboard and twisting the mast base plate. The babystays are for keeping the mast aligned with the boat while raising and lowering.
I realize there are other applications for them but this is one I know of from trailering.
CaptKermie is offline
post #12 of 14 Old 05-28-2008
Thanks Courtney.
I also think it's a downhaul either for the pole, or a downhaul for the staysail, just stored in that position.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #13 of 14 Old 05-28-2008
Moderator
Jeff_H's Avatar
Looking closely it appears that the babystay has a simple turnbuckle and the spin pole downhaul has been snapped onto the stay above the turnbuckle.
Back to the original quiestion. A block and tackle at the end of the babystay is a very typical set up for babystays on smallish (under 40')raceboats with flexible spars. It allows precise mastbend similar to the way an adjustable backstay works on a fractional rig. The tackle can be quickly eased by the pit person on the leeward mark rounding allowing the stay to retract out of the way. There is often a shockchord retractor line that pulls the stay back next to the mast. Sometimes this is rigged as a cascade when more purchase is needed.
A highfield lever makes sense for stays used to fly jibs offshore but makes absolutely no sense on a race boat of this size.
Jeff_H is offline
post #14 of 14 Old 05-28-2008 Thread Starter
Hitchin' a ride
bestfriend's Avatar
Thanks Jeff, sorry for the misunderstanding with my thread title. I know how the baby stay works, it was the line and block attached to it that had me wondering because I want to make mine removable. I couldn't see the rigging very well.
Jeff, just reread and now I understand what you are saying with the addition of the block and tackle to adjust to stay. i like the idea.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
Baby stay 3johno Announcements and Suggestions Box 5 07-18-2007 12:54 AM
vhf no work maestro Gear & Maintenance 1 07-14-2004 08:42 AM
Interior work sneuman Gear & Maintenance 2 01-02-2004 03:16 PM
learning to work on engines? jbarros Gear & Maintenance 5 01-21-2003 05:48 PM
Trade work for boatsit in SF Bay Spring 2002 kunyefish General Discussion (sailing related) 0 11-12-2001 06:29 AM
