  #41 (permalink)
Old 06-15-2008
Irrationally Exuberant
arf145 is on a distinguished road
Saurav, thanks, but I believe my Seafurl is a different model. Mine has a continuous line, thus no stopper knot. Used the old line to pull the new one through. I still need to open it to do a maintenance check, but I'd rather do that separately.
arf145
1987 Pearson 28-2
Chesapeake Bay
  #42 (permalink)
Old 06-18-2008
knothead's Avatar
Here's the eye splice video.
Steve
Ron Paul 2012
"wikijar"
  #43 (permalink)
Old 06-19-2008
Thanks Steve. I'm going to give that a try.
Tom
arf145
1987 Pearson 28-2
Chesapeake Bay
  #44 (permalink)
Old 09-20-2011
NewBaySailor is on a distinguished road
Replacing 7/16" line with 1/2" line for Hood 810 LD
My rigging inspector suggested that I replace the old 7/16" continuous single-loop furling line with 1/2" line because the furler will no longer grab the line and reef - it just runs out. The thinking is that the thicker diameter line might give the furler more to grab and, if pulled in hard, will reef. Anyone try this on their boat with success? Can a 1/2" line replace the 7/16" line for this furler? Thanks! Bruce (Bristol 29.9 on West River, Galesville)
  #45 (permalink)
Old 09-20-2011
knothead's Avatar
Bruce, I would cut a foot or so of the line that you are thinking about buying and see how well it sets into the groove. You might find that 7/16" is what fits best.
IMO you would be best off using a harder line rather than a soft one. But your furler is notorious for being difficult to reef with. If you need to shorten sail, it's sometimes necessary to go forward and secure the drum by tying the tack shackle off to the bow rail or something.
But far be it from me to second guess your rigger.
Ron Paul 2012
"wikijar"
  #46 (permalink)
Old 09-23-2011
papasailor is on a distinguished road
easy adjustment, no need to replace line
The 810 Seafurl is a continuous line. The thickness of the drum slot (with the "teeth" is adjustable. An allen screw on the bottom part of the drum allows the lower part to be adjusted up and down. This will provide more contact with the 7/16" line even if it is worn. Of course, if it is way worn and skinnier in some places then it should be replaced.
However, normal variations can be compensated for by adjusting the drum.
  #47 (permalink)
Old 09-23-2011
tommays's Avatar
7/16 was the max on the boom as 1/2 was hanging up on everything
The knothead videos are great BUT I still had to practice a LOT to reach the point I could do it on the boat in place going through everything and get the right lenth
I have found plain old sat-set does NOT slip on the Stoboom version even when I lock the drum and crank on the halyard
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Replacing furling line in a 331 borisw Beneteau 1 05-26-2008 12:20 AM
Hood SeaFurl 810 repair Rgarv Catalina 2 07-10-2007 10:41 AM
Hood Line rolling furling foil repair mjname Gear & Maintenance 5 11-11-2006 02:20 AM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
