06-02-2008
Not familiar with your boat but I had a rubber rub rail on a boat and it was one continious run all the way around with a joint at the stern. It was 2 piece and the center rub part was interlocked into the outer part, sort of tongue and groove. You could remove the plate at the stern and pull out the outer half to get to the screws behind it. To reinstall the outer half, it took a rubber mallet and a lot of work.
