06-03-2008
Originally Posted by Rockter
No signal return in depths above about 500 ft gives the message "_ _ _" with mine.
I presume a very soft, muddy seabed would give no echo and give the same symptom???
Most depth sounders at 300 ft or greater just either flash 0's or dashes indicating the excess of whatever prescribed depth the unit can handle...
Unless a alarm is going off - usually ok..
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
