Old 06-02-2008
ern-n-jo is on a distinguished road
adhesive advice needed
I am trying to attach (small items)baskets to the galley fiberglass hull. The part that would be attaching to fiberglass is wood. I have tried epoxy and they have managed to fall off. What is the strongest, effective adhesive for this project?
Old 06-02-2008
erps's Avatar
the pointy end is the bow
I've used 3M 5200.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 06-02-2008
LakePirate's Avatar
LakePirate is on a distinguished road
Gorilla Glue.
Just be sure to not over apply it. It swells some has it dries and will ooze out from behind or between the parts being clued. However it can be wiped off it caught in time.
Old 06-02-2008
Sea Slacker
brak is on a distinguished road
Epoxy works just fine but you have to prepare the surfaces. Fiberglass is usually painted - I clean it with Interlux fiberglass wash (or acetone in a pinch) then sand with whatever grit I happen to have (usually 60).
I clean teak with alcohol, and usually it does not need sanding but a bit may not hurt.
I have just done this to make bases for a hanging basket in my locker - you could probably put a whole person in there.
5200 would work too, I suppose.
Old 06-02-2008
Freesail99's Avatar
Freesail99 will become famous soon enough
Have you tried epoxy putty? The stuff comes in a tube, it is like clay or putty, you pinch a bit off, roll it in your fingers to activate it and use it. Holds stuff well.
S/V Scheherazade
Old 06-02-2008
Epoxy should work fine, provided you've prepped the surfaces properly, and you should probably thicken the epoxy with wood flour or microballoons.
Old 06-02-2008
Sea Slacker
Sailingdog attacks the forum
Old 06-02-2008
EO32's Avatar
EO32 is on a distinguished road
He must have been out sailing last week. Didn't hear a peep out of him.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 06-02-2008
Freesail99's Avatar
Nope, he thinks cause he has 22,710 post, he can coast now ......
S/V Scheherazade
Old 06-02-2008
Been on the boat and down at the marina since last Wednesday. Was out sailing yesterday on a Cal 25... did 9 knots at one point according to the GPS. Probably should have had a reef in the main and genny....but didn't.
FL==>NC advice needed boydgatlin General Discussion (sailing related) 6 03-16-2007 11:25 PM
12v & 24v bus advice needed smilie Gear & Maintenance 1 04-25-2006 07:02 AM
Handheld Radio advice Needed natejount Learning to Sail 9 06-25-2003 08:23 AM
Clueless: Handheld Radio advice needed natejount Gear & Maintenance 5 04-22-2003 05:14 PM
Cruising Advice Needed!!! 2 or 3 cabin for 3 single guys? robbieturner Cruising & Liveaboard Forum 5 10-17-2001 05:26 AM
