Old 06-02-2008
vadimgo is on a distinguished road
Yamaha 9.9 problems
Could somebody offer some advice?
After I hit the bridge railing and broke the outboard bracket (it was obviously not my day, shoulda turn back after getting stuck in the mud...) and drowning the motor...
Managed to hang it on some line I had and got it out, washed with fresh water etc.
Got the carb rebild kit, flushed the motor with WD40, changed the spark plugs, cleaned the carb and assembled it with the new kit parts.
Now, clean tank, fuel line and fuel filter, fresh gas...
It starts every time with the choke knob out completely (and would run apparently, as long as I want), but would not run with the choke closed.
Old 06-02-2008
Rockter will become famous soon enough
Why did the carb need re-building?
Old 06-02-2008
The Yamaha manual says once you open it, better to use the new parts - float, seals etc. - and in order to clean it have to disassemble
Old 06-04-2008
Is it too complicatyed or too boring? Nobody is answering in any way...
Old 06-04-2008
Junior Birdman
Iflyka200s is on a distinguished road
Ok, I'll dive in.... I am an A&P (airplane mechanic) I have a 4hp Yamaha 4 stroke) and the carb was giving me fits, the motor wouldn't idle...
I rebuilt the carb
Replaced a boat load of parts
Fussed over the motor for 2 weeks (and I came to the conclusion I should stick to airplanes! (much easier to work on) I took it to the dealer...
Either way, a new carb is like $140... how about buy a new carb and have yours rebuilt as a spare?
I'm out of thoughts, good luck!
1988 Seaward Fox
no name yet (it's in pieces!)
Coconut Grove, Florida
Old 06-05-2008
well, thats a realists' approach...
Will call to see if I can get new carb and the price today.
Thanks
Old 06-05-2008
JimsCAL's Avatar
JimsCAL is on a distinguished road
Since it runs, I would guess either you didn't reassemble the carb quite right or it just needs adjustment.
Old 06-05-2008
LittleMissMagic's Avatar
San Juan 26
LittleMissMagic is on a distinguished road
Was the motor running when it went into the drink? If it was you may still have water somewhere that it shouldn't be. Did you cycle the engine with the spark plugs out? This should remove any water left in the cylinders. When you pull a motor out of the water it is very important to "pickle" it with diesel or kerosene ASAP. This will keep internal corrosion from forming. If you did not do this you may have some corrosion in the cyliderr that may be causing your problem. Your best bet may be to take it to a dealer before you spend the money on a carb that you don't need.
Jon Caisson Bozeman
S/V Little Miss Magic, Pirates Cove, AL
Old 06-05-2008
christyleigh's Avatar
christyleigh is on a distinguished road
My guess would be that it is running waaayyy to lean (remedied by the choke) because either crud or bad adjustment is constricting gas flow somewhere in the carb.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 06-05-2008
timebandit's Avatar
timebandit is on a distinguished road
I am going to assume that will not run or idle with out the choke on but will do both with the choke on.
I would look for a massive air leak after the carb, maybe a torn or missing mounting gasket.
or
A improperly adjusted float level.
Yamaha 9.9 fresh water flush reluctance Gear & Maintenance 6 08-17-2007 02:55 PM
Honda 9.9 4 stroke carburator problems ewjili Gear & Maintenance 13 12-18-2006 12:49 AM
Request: Yamaha 9.9 vs Honda 15 puremajek Gear & Maintenance 3 12-16-2006 08:52 AM
Yamaha 9.9 help need nauticalrich Gear & Maintenance 1 05-26-2003 09:14 AM
