06-03-2008
Last Grumpy Old Sailor
Rockter,
I know it's not the manly thing to do, but have you been reading the instructions?  You're supposed to put a dab of the included sealant/adhesive (I think it's just silicone sealant, actually) on the threads of the top bit to make sure it stays tightened-down. If the top bit is properly tightened and stays that way, ISTM there's no way in hell those wires can rotate. The one where the vertical bit started rotating: Well, perhaps a bit more torque when you tighten the set screw for that? Not too much, as that whole assembly doesn't strike me as all that robust, but perhaps a bit more? (If you want to get really ambitious, you could remove the screw and give it a dab of that sealant, or use a small dab of nail polish or LocTite low-strength (purple) to help it stay put.)
Yeah, those wind indicators are a PITA. We put a brand-new one up this spring. (Last one up and disappeared in the middle of a race.) As luck would have it: Cable from the gin pole caught one of the flags when we were raising the mast and bent it up just a bit. Now the arrow catches on that. So we're going to haul a buddy's youngest daughter up the mast to adjust it.
Jim
s/v Abracadabra
1976 Pearson P30
