06-03-2008
Blueranger-
Check the stainless steel at the hardware store with a magnet. If it is magnetic, it is martentistic stainless and NOT SUITABLE for marine use. If it is not magnetic, it is most likely 304-grade stainless.
However, 316 grade stainless is better, since 304 is much more vulnerable to chloride ion stress cracking and crevice corrosion.
Simple Green will probably do a pretty good job of cleaning the crap and dirt from the boat's deck and cabintop.
