Old 06-04-2008
Finallybuyingaboat's Avatar
Finallybuyingaboat is on a distinguished road
Bolt rope or Sail Slugs
Finally got my boat out for the first time after months of rebuilding, but not sure about the main sail. There is a bolt rope and that is how I raised the sail yesterday, but it really hard to raise the sail. The main has grommets about every 2 feet all the way along the bolt rope and I am assuming those are for sail slugs. Would that be correct? Can I just buy the slugs and attach them? Sorry, new to sailing so I am still learning.
Old 06-04-2008
Don Radcliffe
donradclife is on a distinguished road
You can try it, but when we tried about 15 years ago we found that the sail slugs had even more friction than the bolt rope, and had to cut them off. The other advantage of the slugs is that the front of the mainsail is captured when you drop it.
For some reason the cylindrical slugs tend to jam and bind much more than slides. Does anyone have a source of slugs which don't jam?
Old 06-04-2008
ASA and PSIA Instructor
FWIW, if you have lubed the sail track with silicone spray, and lube the slugs, our main will happily go up hand-over-hand, otherwise I need to use a winch for the second half.
Old 06-04-2008
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
If the grommets are spaced 2 feet apart, they can't be for sail slugs. My guess is they're intended for use with the reefing system. Check the mast for a reefing hook(s) mounted just above the boom to mast connection.
Here's a pic of reefing hooks on my last boat . . .
True Blue . . .
sold the Nauticat
Old 06-04-2008
Plumper's Avatar
Sailor
Plumper is on a distinguished road
They are for slugs if the go all the way up to the top. If there are only two or three and they are heavily reinforced they are for reefs. The slugs bing if they are not installed properly. If they are put on so there is a twisting load on them they will bind but if they are put on so that the load pulls up and down then they work great. I just had all mine redone by a reputable sailmaker and they work perfectly. If I undo my main halyard the sail drops to the deck without effort. Hoisting is just as easy and I have a 52' hoist.
There is a tide in the affairs of men,
Which, taken at the flood, leads on to fortune;
Omitted, all the voyage of their life
Is bound in shallows and in miseries.
Shakespeare, Julius Caesar IV, iii, 217
Old 06-04-2008
TrueBlue's Avatar
Señor Member
Plumper of course, is absolutely correct. Reefing grommets would typically be limited to only two, or three. Whereas, sail slide, or slug grommets would extend the full length of the luff.
Although, normally the spacing is closer than 24". That would result in excessive wrinkles and creases, as well as a foot of sailcloth when flaked along each side of the boom.
True Blue . . .
sold the Nauticat
Old 06-04-2008
If the grommets are every two feet for the length of the luff, then, they're probably for sail slugs. I prefer slugs to a bolt rope, since slugs, when properly installed: create less friction; allow the sail to be more easily flaked or furled on the boom; and simplify reefing the mainsail.
Coating the sail track with McLube Sailcote will help a lot. Clean the track and lube it once or twice a season.
You'll probably need a jackline at the lower end of the luff for the sail slugs.
Old 06-04-2008
TrueBlue's Avatar
Señor Member
Have you checked out the selection of slides and slugs at Sailrite?
True Blue . . .
sold the Nauticat
Old 06-04-2008
Longer slugs are less likely to jam, but make the lowered mainsail stand taller.
Old 06-04-2008
blueranger's Avatar
Mirage 24 Owner
blueranger is on a distinguished road
FWIW a bolt rope is my least favorite method of mainsail attachment. I singlehand 95% of the time and the faster the mainsail goes up the happier I am. I had the boltrope on my Ranger's main go up flawlessly exactly once. The track had just been cleaned and lubed, the sail flaked by someone other than me who knew how to do it correctly (there's a tutorial I need desperately - any good ones out there?), and I left about a foot of sail still in the track from the previous sail which is a fast way to induce UV deterioration of the sail at a high stress point.
I've never had a new out of the box sail with a bolt rope but of the arrangements I've used I prefer slugs. As always YMMV.
Mike
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
Headsail Reefing Basics Brian Hancock Seamanship Articles 0 08-05-2004 08:00 PM
Headsail Reefing Basics Brian Hancock Gear and Maintenance Articles 0 08-05-2004 08:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 07:00 PM
