Blogs
User Name
  #11 (permalink)
Old 06-04-2008
sailingfool's Avatar
sailingfool sailingfool is offline
Originally Posted by AlpineSailor View Post
It's for gelcoat cracks in a small 1981 trailer sailor, an S2 6.7
Perfect looks are not what I'm going for, just want to keep moisture out of the core.
Cracks in the gelcoat should not indicate cause for concern that water will get into a core, unless the figerglass substrate is also cracked - which would be unlikely - but if it were, the substrate should be gound out and repaired with new glass.
More likely any wetness in core would be traced to failing bedding.
If you have typical spyder-cracking in gelcoat, repairing it with gelcoat is the best way to go, from any perspective. Once agin, try to figure out how to correct the source of the spydering.
SF
CS 36T
Where are those skiis...
  #12 (permalink)
Old 06-04-2008
AlpineSailor's Avatar
AlpineSailor AlpineSailor is offline
AlpineSailor is on a distinguished road
Yep, rebeding the hardware is on the list too.
I was hoping for an easy fix on the gelcoat cracks as I have bigger jobs to deal with, but I may be better of skiping the Life Calk and do it the right way at some point.
Thanks for the input.
  #13 (permalink)
Old 06-05-2008
Sypder cracks are a common cosmetic problem, many owners live with them without a thought, letting them go until when/if you can correctly address them is a reasonable approach...
SF
CS 36T
Display Modes
vB code is On
Life Raft Stowage: The Overlooked Necessity PracticalSailor Gear and Maintenance Articles 0 07-09-2007 02:21 PM
gelcoat cracks in nonskid fupa Gear & Maintenance 4 09-25-2006 12:51 PM
Gelcoat Cracks brainsboy General Discussion (sailing related) 6 03-25-2006 01:38 AM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
Recovering the Shine Don Casey Gear and Maintenance Articles 0 08-04-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
