Old 06-04-2008
GBurton is on a distinguished road
Raymarine ST30 speed controlhead
Thanks for all the help finding out what instruments I have
I have ascertained that the speed controlhead is a ST30.
I connected it up on the bench and the display came to life but the speed readout is "hunting". I do not have the little speed transducer hooked to it so I'm hoping someone will tell me that this is what the instrument will do if the transducer is not hooked up and all is well.
Yes, I have read the manual.
Old 06-04-2008
It's a speed instrument...it measures a small signal sent by the rotating wheel in the transducer..the paddle has magnets inside...so as it rotates, the 4 or 5 or 6 paddles create a magnetic flickering...the instrument coverts the magnetic flickering of the paddle wheel sent either as either millivotage or milliamps..not sure...and the system counts the number of RPM's. The RPM is then based on a basic function generator thru a simple logic single chain loop convert RPM into desired value, Feet/second, Miles/hour, knots, KM/hr..etc...
If its not connected you gett lines ------ or nothing or error..as the signal is sent but has no return....
Basically the gauge is a frequency gauge, so without the whell rotating and inducing a flickering nothing will be read..nada zilch..
For your answer I will charge you $5.00
Old 06-04-2008
Please read the question again.
The sensor has 3 wires so it may not be a simple discrete input. It could be an analog signal ie 0-10 volt or 4-20ma.....this is what I'm trying to find out.
Old 06-04-2008
chucklesR's Avatar
Gemini 105Mc Hull 987
chucklesR is a jewel in the rough chucklesR is a jewel in the rough chucklesR is a jewel in the rough
The transducer is a simple plug in on that, try it out and spin the paddle.
Then again, you didn't picture a transducer so I deduce you don't have one and maybe the previous owner had not gotten around to the through hull either. That means you are lucky and get to pick which part of the boat gets wet on a regular basis.
That being the case any NMEA 0183 compatible unit will work and can be wired in. It's only 3 wires, the wiring in the manual conveniently leaves out which is which (got bored at lunch time and read it).
In order to get all your displays working and talking and in particular to get the true and apparent wind to calculate properly you will need the speed log running in conjunction (talking to) your windex.
Good luck.
Old 06-04-2008
Cheers Chuckles - transducer is not handy (its at the boat)
Old 06-04-2008
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
If you get anything on the log screen without the sensor attached, its a hopeful sign, but no guarantee the thing will actually work properly.
Jonathan-Livingston
Old 06-04-2008
chucklesR's Avatar
GB,
somehow you bring out the wrath in people.
Your initial question did not mention 3 wires or any feed at all.
I mentioned them in my post, and also intimated that the manual doesn't mention the color coding clearly.
I would suggest you expirement by getting a transducer, wiring it and spinning the wheel -
or
here's and idea
post a thread with ST-30 speed log wiring help as the subject; then double read your question to make sure you provide all relevant data.
Me, I'm done helping you until you play by the rules everyone else plays by.
Old 06-04-2008
Yeah - thanks Idiens I realise that. I'm hoping someone has run into this exact scanerio with this controlhead
Old 06-04-2008
chucklesR's Avatar
Shoot it 5v at 5ma and see what you get. If it breaks it wasn't working anyway
Old 06-04-2008
I do seem to bring out the worst in some people. Strange.....although usually they are very self important people.
Originally Posted by chucklesR View Post
GB,
or
here's and idea
Speed Week Redux Dan Dickison Racing Articles 0 09-27-2002 08:00 PM
The Need for Speed Dan Dickison Racing Articles 0 10-03-2001 08:00 PM
Speed Sailing Overview Dan Dickison Racing Articles 0 05-16-2001 08:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
