Dingy davits - SailNet Community
Blogs
Old 06-18-2002
928frenzy is on a distinguished road
Dingy davits
I''m considering installing davits that can hold my 10'' Porta-Bote in the "set-to-go" position. I''ve seen davits with two arms that hold the dingy over the transom. I''ve seen others that hook the dingy along a gunnel while the other gunnel is pulled up out of the water. The latter is cheaper, but they most likely will casue the rear view from the cockpit to be obscured. Also, with the dingy in a near vertical position, I would think that it may act as a reverse sail, and the motor could not remain mounted on the dingy.
Are there any other davits that can work? The least expensive "ready to go" davit system I''ve found is about $550. Does anyone know of a better price? TIA.
~ Happy sails to you ~ _/) ~
Water Tender Dingy 9.4 gunnyman1 General Discussion (sailing related) 5 07-11-2008 07:39 PM
tow dingy with outboard? Marty Levenson Seamanship 13 04-18-2006 11:39 PM
Dingy on davits DavidMilne Gear & Maintenance 4 07-23-2003 09:30 AM
Dingy on davits at sea DavidMilne Boat Review and Purchase Forum 1 07-17-2003 06:16 PM
Dingy Outboard Motor rclampitt Cruising & Liveaboard Forum 9 02-22-2003 03:14 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
