06-05-2008
ASA and PSIA Instructor
Originally Posted by bushrat
.... I thought I would start with the unfinished hatch covers. They seem to me the same teak plywood as the rest of the interior panals. I tried Helmsman clear gloss on them. It went on very easily with no sags or runs. After two coats they look just ok. ...... I am also concerned about future maintenance and durability. .
Newly varnished teak should look breathe-taking, how did you clean and prep the teak before varnishing, tha tis half the job.
As to varnishing the interior, how long do you expect to keep your boat...if you expect to keep it for more than the life of the varnish application, say 6-10 years, then don't put the varnish on, because you never want to be around when it needs to all be removed. In other words, don't use varnish, unless you have a yacht where money and time are no objects, and only the best will do. I've recently put one coat of Cetal natural teak on my interior after cleaning and I find the result very pleasing, if a slight bit of a compromise.
