What Spare Parts Do You Carry Aboard Your Boat?? - Page 2 - SailNet Community
post #11 of 41 Old 06-05-2008
DrB
Extra, Extra, read all about it!!!!
I have the following:
  • Two quarts of engine oil
  • Two Oil Filters
  • Two Water Separator/Fuel Filters
  • Two Secondary Fuel Filters
  • Multiple Seawater Impellers
  • Extra Lines
  • Extra Jib
  • Extra cotter pins
  • Duct Tape
  • Gallon of 50/50 Cooloant
  • Portablee Battery Jumper
  • Flashlights with extra batteries
  • Flares/Extra
  • Miscellaneous Shackles/Pulleys
  • About $20
  • Extra engine keys
  • Full Days worth of non-persishable food and drinks
DrB
DrB is offline
post #12 of 41 Old 06-05-2008
cap'n chronic
cnc33voodoo's Avatar
my boat is a floating hardware store as i know the feeling of getting stuck in a storm and make sure im always prepared for anything.
theres nothing like having the right tool for the job if you get in a jam.i built a compartment in my quarter berth dedicated to safely storing tools for whatever pops up.
plus
-electric trolling motor.
-booster pack
-winch spare parts
-impellar
-fuel line,seacock tubing,clamps
-t-stat
-engine oil
-lock tite
-spark plugs,wires,coil,points,condensor,fuel filter/water seperator
-sealants,rigging/electrical,butle tape
-fuel
-doubles of all safety gear
-headgasket rebuild kit
-ropes,blocks,cleats,roll of cable with clamping tool and fittings,bungees
-electrical-tape,wiring,butt connectors,butane soldering kit(doubles as a torch),bulbs,fuses,dvom.
-snorkel/goggles (which i pray i never use)
-back up tiller
-2 50000 candle light power flashlights
-hardware toolbox-nuts/bolts/washers/turnbuckles,cotter pins,dowel pins
-cable cutters
-assortment of shore power converters
-most importantly a spare bottle of jack daniels for liquid confidence just in case all else fails
sd-its funny that you mentioned shear pins as 2 years ago on my 24 footer a spare would have saved me a tow-back.
cnc33voodoo is offline
post #13 of 41 Old 06-05-2008 Thread Starter
I didn't include tools in my list, since tools aboard have been covered in previous threads. I also didn't include generic parts, like nuts, bolts, screws, clevis pins, and such.
I do have a backup tiller.
sailingdog is offline
post #14 of 41 Old 06-05-2008
captainrizzo's Avatar
I keep multiple items on this list.
2GMF Minor Kit:
104500-55710 FUEL FILTER / ELEMENT FOR MOST GM AND HM SERIES ENGINES AS WELL AS SOME QM ENGINES SEE DESCRIPTION FOR DETAILS
104511-78780 V-BELT, Water Pump
119305-35151 FILTER Assembly, LUBEOIL
124060-59380 PLUG, BLEEDER
124223-42110 GASKET, WP COVER
128270-12540 AIR FILTER / ELEMENT / SILENCER
128296-42070 IMPELLER, COOLING WATER
23418-060000 BLEEDER PLUG PACKING
24341-000440 O-RING 1A S-44.0 for fuel filter
25112-003601 V-BELT A 36
726 Water Resistant Parts Box
90149 Cooling Treatmemt 12 oz
90165 Marine Formula 32 oz
Also have a spare lifter pump, spare fuel strainer, 3 racor filters, antifreeze, oil, sheaves, pins, shackles, lines, Yanmar repair manual, a tool kit necessary to replace any of these parts and enough beer in case things go really bad!
-Riz
captainrizzo is offline
post #15 of 41 Old 06-05-2008
T37Chef's Avatar
Post Why I have had to raise the water line...
  • All Engine belts (3 types, two for water pump)
  • Most engine hoses
  • Impellers & Gaskets (1 new, two old but still good)
  • Fuel Filters: Engine & Racor (2 of ea.)
  • Oil Filters (2 ea. & Oil)
  • Thermostat (1 new, 1 old but working)
  • Spare 2 bladed prop (the original)
  • Old Stuffing box & necessary packing (converted to drip-less this year)
  • Yards of lines & sheets
  • Multitude of blocks and rigging hardware
  • Pins for outboard prop
  • Variety of fuses from 1 amp to 20 amp?
  • Various light bulbs, for sure running lights
  • Electrical connectors, shrink tube, & wire
  • Fresh water pump kit (potable water, not engine)
  • Head Kit
  • Emergency Jump Start thing, does that count?
Thats all I can think off right now, these days I find myself starting to remove more than keeping it all on board.
Shawn
T37Chef is offline
post #16 of 41 Old 06-05-2008
moderate?
camaraderie's Avatar
In addition to the usual stuff most carry...we also carry a spare alternator and complete major parts engine kit.
The list is simply too long for everything else...but essentially we have backups or repair kits for most everything...standing and running rigging, navigation aids, pumps and motors, fluids, and all the tools and parts needed to fix stuff that breaks. When in more remote ports, may not have the skills to fix something yourself...but if you have the part...you usually can find someone who can do the job.
camaraderie is offline
post #17 of 41 Old 06-05-2008
I'd rather be sailing
labatt's Avatar
On top of a lot of the above, I keep aboard most of the items I've replaced or upgraded, like blocks, line, electronics, etc.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #18 of 41 Old 06-05-2008
1997 Dehler 33
max-on's Avatar
I'm feeling a bit 'small'; are all you guys going offshore from New England to the Carib, or constantly prepared to do so?? Spare pumps, alternaters, motors, engine rebuild kits, extra tiller, etc???? Wow.
If I was going to Bermuda, I would increase the inventory, but for every day, I carry a spare main and genoa - the originals (after all it is a sailboat ), a basic tool bag, fuel filter, raw water impeller, and engine belts, some misc hardware - clamps, pins, blocks, line, etc. Except the safety related gear, water hose, and electrical cord, that is it. Why would I want all that inventory for everyday?
max-on is offline
post #19 of 41 Old 06-05-2008
Are you crazy????
Don't you read sailnet????
Are you nuts????????
YOU DON'T HAVE A WEST MARINE INVENTORY IN THE BOAT????
you are a Dare Devil...
What if a Tsunimamy hits you?? you get a knockroach???
What if you close your eyes...go to sleep and wakeup doing blue water???
You are out of line.......should be banned....
not carrying spares...you are crazy.....
Giulietta is offline
post #20 of 41 Old 06-05-2008 Thread Starter
Gui-
Max-on is a lawyer... he'll just sue the responsible parties if the weather goes south or something breaks. This is America, land of litigation.
Originally Posted by Giulietta View Post
Are you crazy????
Coastal v. Bluewater cruiser, your thoughts EveningStar Sailboat Design and Construction 17 11-02-2007 07:13 PM
Name Change for Older Yacht ChiefOren Boat Review and Purchase Forum 12 10-08-2007 11:59 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 09:00 PM
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 08:00 PM
The Balance of Hull and Sails Steve Colgate Buying a Boat Articles 0 05-25-2000 09:00 PM
