Old 06-06-2008
jason3317 is on a distinguished road
Recommended Alternator Belt + Length
I am in process of upgrading the charging system on a Yanmar 2GM20F. I have a Balmar alternator with the 2.5" diameter pulley. I believe I will need to supply a shorter effective length belt.
What is the recommended length of this new belt, based on experience of others?
Jason
Old 06-06-2008
JohnRPollard's Avatar
Moderator
Hi Jason,
When we added a Balmar alternator to the 2GM20F on our previous boat, I seem to recall that the belt length was the same as it had been previously with the OEM Hitachi alternator. We did, however, need to upgrade to a heavy duty belt in order to withstand the new load/drag of the higher amp alternator. We went with a proper length "Gates Green Stripe" belt.
Old 06-06-2008
Valiente's Avatar
No clue as to the length...use a string and measure the string or measure the old belt.
But I second the Gates Green Line make...they are recommended by others besides me as being tougher and more reliable than most.
But nothing beats having the proper tension. On most 35-100 amp alternators on 30-80 HP diesels, this means tight enough so that an average person's thumb can deflect the tightened belt about the thickness of a dime or two, i.e. not rigid, but still pretty snug.
This can be tricky to achieve solo, but leaning gently against a pry bar while you tighten the armature mount bolt usualy works for me.
Old 06-07-2008
Gates Green Stripe is the way to go
Thanks for the feedback. I agree on using the Gates HD series belts; I picked up a stock length (37") and, also, a one inch shorter belt in case the smaller pulley needs it.
Jason
Rule of thumb for mooring pennant length? jonlgauthier Gear & Maintenance 9 06-04-2007 10:32 AM
LWL v. Wave Length kreton General Discussion (sailing related) 1 10-08-2006 03:30 AM
Whisker Pole Length mikehoyt Racing 1 07-08-2004 08:18 AM
Displacement vs Length TADIAS General Discussion (sailing related) 5 12-16-2003 06:54 AM
Boat length and solo sailing maxcontax General Discussion (sailing related) 5 03-21-2003 07:07 AM
