Old 06-06-2008
kaakre is on a distinguished road
Tapping 12V from 24V System
Am ferrying an old Euro boat with 24V windlass and starter/ alternator. I will be adding temporary 12v user circuits for electronics, lights and so forth. The boat is currently stripped without a single piece of wire in the hull.
So-- I could run it at 12V with a 12V alternator and combine the batteries in 24V series by switching when I need to start or use the windlass. Some problems with that though-- no load on the disconnected 12V alternator at engine start comes to mind.
Or-- and here is the question-- can I tap off 12V through leads to one battery while both batteries are hooked in 24V series?
Thought it might work but I like to avoid the larger explosions when possible!
Keith
Old 06-06-2008
Using 12VDC off of one battery in a 24VDC system is a really bad idea. IT will cause the batteries to age differently and lead to other issues in the long run.
Your two options are:
1) Set the boat up with a 24 VDC system and use a DC-to-DC converter to provide 12 VDC where necessary.
2) Set the boat up with a 12 VDC system and use a DC-to-DC converter to provide 24 VDC where necessary.
However, given the amperage of a windlass and starter motor, it might be wise to use a third option, which is to have both a 24 VDC and a 12 VDC system on the boat, with separate panels, charging, etc.
Old 06-06-2008
I'd rather be sailing
labatt will become famous soon enough
I would tend to agree with SD. Using step-down converters is generally acceptable, except I would run a separate 12v system for the high amp stuff. I believe that's how Hallberg-Rassy does it.
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 06-07-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Even on a 12V with different banks your batteries would age differently anyway (house and starter for instance), there is no problem at all to tap for a 24V eventually. DC -DC converter is a bad idea, it will pose unecessary loss, and will be a beast in size if you intend it to start your engine or a windlass from 12V system. Problem will be to have a combined bank for starter rather a separated one (single point fo failure), and you'll need your alternator a 24V, or your switching will be a big mess (big switches and many contacts).
Old 06-07-2008
speciald's Avatar
Special Delivery
speciald is on a distinguished road
Send a message via Skype™ to speciald
I have two systems on my boat - 24v. for the house, winches, windlass and 12v. for the electronics. That means I have two battery banks, two battery chargers, and two alternators. Lots to go wrong or break - and something often does.
Old 06-08-2008
Valiente's Avatar
Funny this should come up: a friend preparing to go south gave me a call this morning and said there was an Air-X wind gen still in its box, never used at a boater's yard sale. I got it for $350, about 40% of what I should've paid for new and frankly cheap enough for me to "experiment" with before we go south.
Only issue is that its a 24 VDC model. So I'll have to wire it in a particular way to charge a bank of either two 12 volts (the current house) or four to eight 6 volt golf cart batts in series/parallel.
I agree with the separate 24 VDC system for the windlass, but that's a lot of work for the single application...but the payoff is power when you want it
Old 06-08-2008
One other point... the wiring in the boat, which is setup for a 24 VDC system, isn't going to be heavy enough for a 12 VDC in most cases. Since the higher the voltage, the lower the amperage, it is generally okay to go from a 12 VDC system to a 24 VDC system in terms of wiring, but not the other way around.
Old 06-08-2008
Thanks
Thanks for some good ideas.
Another input from another thread here:
Look up the wiring for a series/parallel switch used on big rigs (trucks). 12 volts to run all the trucks accessories except the starter, which is 24 volt and activated by a solenoid that changes two banks paralleled to series (and it doesn't mess up the rest of the system)
Keith
24V to 12V tgeewe Gear & Maintenance 12 01-23-2008 02:41 PM
Getting confused on an electrical system - 12v, 24v, 115V, 220V... labatt Gear & Maintenance 7 10-08-2007 10:05 AM
12v system and 24v system on 1 boat at same time? BigCatOne Gear & Maintenance 5 05-21-2007 07:55 PM
12v & 24v bus advice needed smilie Gear & Maintenance 1 04-25-2006 07:02 AM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
