06-09-2008
Harp..
Very similar to my MD17C, from 1977.
Take the thermostat out of there... it is on the front end of the exhaust manifold. Just take off the thermostat and put in a saucepan of water, and raise the temperature slowly. You will see it open clearly. It means buying a thermometer, of course.
Try to check what thermostat you bought. If it is the raw water type, I suspect it will open at about 75 degC.... but I am guessing. There should be a part number on it to confirm, and Volvo should know. Remember that the thermostat for closed cycle cooling with heat exchanger is different and is designed to run hotter... I think about 90 degC. Don't put that one in your raw water cooled motor as it tends to cause aggressive scaling.
On my motor, the temperature makes it to about 12 O'clock on the guage, then drops back, repeating all day.
Harp... just be wary it does not stay in the red.... then you really are overheating it.... then you will probably hear it bubbling on shut down (not the normal short-term intermittent gurgling as the water settles), but a clearly audible boiling in the motor that slowly subsides. I have been there with that one in the Gulf of Mexico and it was horrible.
That is not what is happening to your motor.
Be wary that the wee water entry ports in the cylinder heads do not scale up. One of mine did, and the fwd piston and cylinder head got overheated. The ports are easily cleared though. A coat hanger will do fine. The scaling is a black, biscuit-like material, but it clears with effort with the wire and with a wee hose to flush it out. Poke the scale off the corresponding manifold feed port too.
If ever you suspect that it needs done there Harp, give me a shout. It is among the easier jobs on a raw water cooled Volvo.
It's a good motor, it really is, and it's from the old cast iron school of design, but with truly shocking spare parts prices.... like off the clock.... about $2300 for the exhaust manifold on mine, back in 1997. I shudder to think what it would be today.
A last point. Don't let the motor freeze there Harp. I did. There is a crack, but it is not worsening.
Rockter.
