Old 06-08-2008
davidpm's Avatar
davidpm is on a distinguished road
Weeping fuel lines
Two out of 3 injectors on a universal m25 seem to be leaking a little. I'll tighten them as much as I dare but what is the next step?
I took off the injector hose/pipes and polished the end of the fitting and cleaned everything as best I could.
Engine starts and runs very well so I hate the idea of replacing the injectors but even though it is only a few drops raw diesel doesn't sound like a good idea.
Old 06-09-2008
timebandit's Avatar
timebandit is on a distinguished road
New banjo washers??
Rick
Old 06-09-2008
djodenda's Avatar
djodenda will become famous soon enough djodenda will become famous soon enough
Originally Posted by timebandit View Post
New banjo washers??
Rick
I agree with timebandit
David
1987 CS 36 Merlin "Kyrie"
Old 06-09-2008
davidpm's Avatar
How suicidal is it to run the boat with fuel lines that weep about a drop every minute or so?
Old 06-09-2008
erps's Avatar
the pointy end is the bow
Not suicidal in my opinion, but it will be stinky and it may get into your bilge.
Also, IIRC, the M25 has fuel return lines secured with its own nut and washers underneath the injector fuel pipes. The fuel pipes should be steel and capable of withstanding a good amount of torque. Maybe your leak is a little lower at the fuel return lines.
Here's a link to a parts manual over at the C-34 website.
http://www.c34.org/manuals/Parts-List-1of2.pdf
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 06-09-2008
davidpm's Avatar
Thanks for the parts list Ray
What is a banjo washer where does it go, what does it look like and is it something I can change myself?
Old 06-10-2008
A banjo washer is a thin copper washer that is inserted between the banjo bolt and the fitting the banjo bolt screws into and is designed to act as a seal. They're usually considered sacrificial and often one-use.
They are also often referred to as "crush" washers, since they are usually "crushed" when installed properly. Do not over-tighten the banjo bolts, since that is often a cause of leaks such as the ones you're describing. Below, is a photo of some fittings, including the crush washers, which are aluminum in this case.
BTW, having a slow diesel leak can also result in huge fines if your boat pumps some overboard and you get caught doing so. There is an international treaty against oil discharge, and this covers recreational boats, and in the US, the EPA and USCG has been cracking down on it.
So fixing the problem may be a very smart idea, unless you like paying the government thousands of dollars in fines.
Bleeding your Yanmar Engine artbyjody Gear & Maintenance 31 03-22-2012 02:36 PM
Universal M21, long story and fuel line question BarryL Gear & Maintenance 16 05-12-2008 03:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
