Old 06-08-2008
johnr
jr438234606 is on a distinguished road
Aluminum or Steel?
Ok all you metallurgist out there: In the process of doing my repower I have found it necessary to adjust the engine bed in order to get the engine to the right height relative to the shaft. I don't want to use GRP to modify the existing engine bed, which was constructed when the hull was originally laid up, so it's very strong. I would rather adapt it to what I have now using metal of some sort with heavy fasteners.
I've designed a bracket to fit perfectly. I'm going to bring it to the machine shop tomorrow and have them fabricate a pair. I just need to know what to tell them to make it from: Stainless steel, or aluminum?
Aluminum would be lighter and cheaper to fabricate. But would it stand up to the vibration? Steel would be stronger (I think?), but would it be overkill?
I've including some photos. Any advice is appreciated!
Old 06-09-2008
You'll have fewer corrosion issues down the road with SS, and since you're on the isolated side of the engine mounts I don't think vibration will be a huge issue
1984 Fast/Nicholson 345
Old 06-09-2008
Rockter will become famous soon enough
Design to get them out of there fairly easily. Given the choice I'd go for stainless, but don't paint it. Watch that the vibes do not loosen those stud fasteners. Keep checking.
Old 06-09-2008
You really want to use stainless steel. Two major reasons: 1) it is more corrosion resistant and will generally have less problems in that area of a boat; 2) it is far more fatigue resistant. Vibration may cause aluminum to fatigue rather quickly.....and lead to the bracket failing.
Old 06-09-2008
Sasha_V's Avatar
Sasha_V will become famous soon enough
Get it machined in a solid engineering plastic like vesconite.
Better at coping with vibration, dampens sound instead of transmitting it. Totaly corossion proof and lighter then either stainless or aluminium. Stainless will work harden fomr the vibration and eventually become either brittle or lose its chromium and rust (depending on type). Aluminium will be like a sacrificial annode in that location and application...And you would want to get it in a soft temper like T3 or T4...T6 will workharden and crack too.
Old 06-09-2008
I wouldn't recommend Vesconite due to some of its limitations:
Vesconite is suitable for continuous use at 100ş to 120°C (212ş to 248°F) in dry conditions and 60° to 70°C (140° to 158°F) in wet conditions.
What do you think the average temperature of an engine room in a small sailboat is when the engine is running??? Considering that the thermostat on a raw-water cooled engine is set for 140˚F... it is probably a bit warmer than that near the engine.
Old 06-09-2008
Valiente's Avatar
True, but at the bottom and aft, away from the block and the oil sump?
I simply don't know the answer for that area. I do know the answer for the head: friggin' hot!
Old 06-09-2008
beej67's Avatar
beej67 is on a distinguished road
I sure as hell wouldn't want a plastic engine bracket in my boat.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
Old 06-09-2008
pfatyol's Avatar
Swansea, MA
pfatyol is on a distinguished road
316 Stainles or 17-4 ph SS (17-4 annealed not heat treated) would be a good choice. 316L is not worth the extra money for an engine mount.
Patrick
S/V "Fat-Kat"
C&C 32, Hull #237
Mt. Hope Bay
Old 06-09-2008
rheaton is on a distinguished road
You might consider fabricating the piece our of fiberglass and epoxy. machine this piece to fit then use 5200 to attach it. This would be strong and would not rot or corrode. I saw this described for use as a backing plate for a thru hull fitting.
Rust Never Sleeps John Kretschmer Buying a Boat Articles 0 02-27-2003 07:00 PM
Rust Never Sleeps John Kretschmer Gear and Maintenance Articles 0 02-27-2003 07:00 PM
Spade Anchors Aluminum vs Steel thomsonjd Gear & Maintenance 1 12-31-2001 12:54 PM
Steel or Fiberglass Mark Matthews Buying a Boat Articles 0 10-21-2000 08:00 PM
Steel or Fiberglass Mark Matthews Gear and Maintenance Articles 0 10-21-2000 08:00 PM
