Problem Seacock -dripping. Is this abig deal? - SailNet Community
post #1 of 33 Old 06-09-2008 Thread Starter
Pamlicotraveler's Avatar
I noticed a leaking (dripping) seacock this weekend and am wondering if it is a serious problem. I am attaching images, and after looking at the pictures I have to say they look scarier than I perceived at the time.
I noticed a small stream of wet area leading to the bilge. I noticed the base of the seacock. This is a forward seacock in the v-berth that feeds the forward head and an air conditioner.. It is dripping from the tapered plug, not at the base, although the base itself doesn't look too good, probably because it has been wet. I am hoping to wait until after this season to haul the boat and have the baseplate replaced.
My question is, is it safe, and advised, to tighten the nut to stop the drip while the boat is in the water? Will that likely stop the dripping? The dripping is 3-4 drip per second - that is to me substantial. It appears to stop dripping when it is off, so I have left it off and hopefully will dry out the base plate until I am there.
Also, is all of this corrosion a sign of some galvanic issue, or is that just a byproduct of the drip?
(Why am I only able to display the link to the photo in the post...other times I have been able to post the actual image in the body of the post???)
"Tell 'em I'm busy. I'm on a sails call."
Last edited by Pamlicotraveler; 06-09-2008 at 12:02 PM. Reason: trying to display the image in the post instead of the link...
Pamlicotraveler is offline
post #2 of 33 Old 06-09-2008
beej67's Avatar
Anything dripping below your water line is a big deal. I'm no expert, but looks like time to haul and replace it, to me.
beej67, Checkered Past, 1980 32' Pearson 323, Panama City FL
beej67 is offline
post #3 of 33 Old 06-09-2008
lbdavis's Avatar
I'm going to have to go with beej on this one. The gold standard here would be to replace.
My concern with tightening is that you do risk a larger leak. It is quite possible that the threads in there are corroded and barely holding on. I had this happen to me on 1983 Perko seacock this winter that I was servicing. I was on the hard, so it wasn't an issue...
Are you using the button in the middle for inserting pics:
lbdavis is offline
post #4 of 33 Old 06-09-2008
Freesail99's Avatar
I would NOT tighten any bolt it may break. It is time to haul and replace it, please don't wait to long. If the dripping is 3-4 drip per second, that is substantial.
Good Luck,
Paul
S/V Scheherazade
Freesail99 is offline
post #5 of 33 Old 06-09-2008
moderate?
camaraderie's Avatar
Holy moly Batman! Don't touch that sea **** till the boat is OUT of the water. Get it out quickly.
camaraderie is offline
post #6 of 33 Old 06-09-2008
Good Luck,
Paul
I agree with Paul, this is CRITICAL I don't like the looks of the seacock at all. It is bonded also, if the zincs have not be maintained it can be eating away from the inside. Replace and Replace NOW!
bubb2 is offline
post #7 of 33 Old 06-09-2008
WinterRiver's Avatar
I agree with the replace crowd.
You don't want it to escalate to this or worse:
A recent discussion of faulty seacocks, and some good maintenance advice: Seacock Surprise
WinterRiver is offline
post #8 of 33 Old 06-09-2008 Thread Starter
My thoughts exactly guys. Dang... Another trip to the boatyard and more boat units even though I just had it hauled and had the seacocks "serviced" and several base plates replaced in APRIL!!
P.S. Why are my pictures showing as links instead of in the post like they usually do. I've tried larger pics and smal and this time, for whatever reason, they are showing as links. I am using the insert image icon the same way I always do.???
post #9 of 33 Old 06-09-2008
Freesail99's Avatar
If you had the seacock serviced in the picture you just showed:
1. See about a refund from the Marina.
2. Check your zincs!!!!
S/V Scheherazade
post #10 of 33 Old 06-09-2008
Had a similar looking thru hull on a Cape Dory, though it wasn't leaking. Found the internal threads of the thru hull were almost completely gone with corrosion and just a hair of both flange bolts were left. It was VERY EASY to remove. I would agree...you're really flirting with a disaster and I wouldn't BREATH on that thing! Hope you have a tapered wood plug handy until you can pull the boat.
Also I noticed the valve is bonded. With stray voltage, that could be part of your problem....but boy, that's another whole 'do or don't' topic for discussion!
Bob
fullkeel7 is offline
Yanmar 2GMF starter solenoid mdemuth Gear & Maintenance 14 04-10-2013 08:46 PM
Assemble thru-hull & seacock...how? flyhop Gear & Maintenance 10 04-09-2008 04:53 PM
