Yes, you're going to have to replace the wood. If the area is greater than one square foot, you're generally better off re-coring, rather than injecting
epoxy. Marine grade plywood is not the best core material, since it is heavier than polyureathane foam or end-grain balsa, and has the worst properties of both—wicks water like foam and rots like balsa.
I'd re-core the area, but leave the area at the edge, for about 1/2" to 1" around the port solid fiberglass.
POST.
