Blogs
User Name
  #11 (permalink)
Old 06-10-2008
Rockter Rockter is offline
Rockter is on a distinguished road
Scott...
Neat tank, but how do you inspect that one?
Shouldn't there be a big hatch in the top?
From time to time it's likely to get gummed up in there.
  #12 (permalink)
Old 06-10-2008
1970Columbia34's Avatar
1970Columbia34 1970Columbia34 is offline
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Its a Gas Tank not a diesel tank, if it were a diesel tank you are right you would want to be able to open it up.
Scott
  #13 (permalink)
Old 06-10-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
You generally don't want any extra openings in a gas tank... BOOOM!!!! is a bad thing.
Originally Posted by Rockter View Post
Scott...
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
  #14 (permalink)
Old 06-10-2008
But if water gets into it, how do you ever get it out?
Is there a way of purging water from it?
  #15 (permalink)
Old 06-10-2008
timday5 timday5 is offline
timday5 is on a distinguished road
Why wouldn't the water just suck out through the withdraw tube and end up in the water-fuel seperator?
  #16 (permalink)
Old 06-13-2008
MIKEMCKEE's Avatar
MIKEMCKEE MIKEMCKEE is offline
MIKEMCKEE is on a distinguished road
I am going to go with my yard tech's advice, pull the old tank and clean the inside good and then my sludge problems should be fixed. Thanks for all the support and help.
Chief
  #17 (permalink)
Old 06-13-2008
The problem is when the water just sits there, for years, sometimes salt-laden, or too much gets in there and stops the show.
Perhaps you could suck it out with a wee pump?
  #18 (permalink)
Old 10-05-2008
tdw's Avatar
tdw tdw is online now
Plain Mr Wombat (TD)
tdw has a spectacular aura abouttdw has a spectacular aura about
Easier to resurrect this thread than start anew.
Aluminium Fuel Tanks.
Whats the thinking ?
Funsailthe keys - says "too problematic"
Omatako is in favour. O, you have the experience but if you don't mind would you expand on why you like them ?
Cheers
Greatness is not where we stand, but in what direction we are moving....we must sail, sometimes with the wind, sometimes against it, but sail we must, and not drift nor lie at anchor.- Oliver Wendell Holmes
  #19 (permalink)
Old 10-05-2008
TDW-
If you have a dry bilge, aluminum is fine...if not...get stainless steel, since aluminum and wet bilges are a bad combination.
  #20 (permalink)
Old 10-05-2008
Omatako's Avatar
Omatako Omatako is offline
Omatako is on a distinguished road
TDW, your reference to my "experience" makes me nervous - I'm not even close to being expert on fuel tanks.
My preference for ali is really about weight:strength ratio and probably more importantly, a frivolous desire to have things neat and tidy. Ali tanks are lighter even with quite thick material used and the tanks generally retain the squareness that was intended and fit easily into the tight spaces intended to house them.
My experience with stainless tanks is that the material gets real thin and is subject to a lot of distortion, especially if the tank is big (200 litres or more). By the time baffles and fittings are welded in, the box looks anything but regularly-shaped.
The tank shown above (Scott's) looks really nice but, with respect, it is very small and the top is already wavy from the welding heat and it doesn't appear to be baffled.
If the cavity you're using is uniformly constructed then HDPE is probably a good alternative but I would wager that they only come in standard sizes, without baffles and with standard fittings (size and location). They are also probably very expensive to customise and are not freely available in non-standard shapes. In my experience, most (or maybe all) of these type of tanks are roto-moulded and to make a mould for a one-off shape is not practicle. I've never researched these so this is just my own speculation. Don't plan your tanks based in this opinion.
"I think it would be a good idea"
Response from Mahatma Ghandi when asked what he thought of Western Civilisation.
Display Modes
vB code is On
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 08:39 PM
Fuel tank Replacement samchristo Pacific Seacraft 3 08-06-2007 10:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 08:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 08:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
