Old 06-09-2008
MIKEMCKEE's Avatar
MIKEMCKEE will become famous soon enough
fuel tank replacement
I've got a 1976 Irwin 37CC sailboat and I am thinking about either replaceing it with a bladder or slipping in a smaller one in it's place, any ideas ?
Mike McKee
s/v Blue Bayou
Old 06-09-2008
fullkeel7 is on a distinguished road
No expert Mike, but I've never read anything good about fuel and bladder tanks without a lot of effort given to eliminating all hard spots surrounding the bladder. Water either for that matter, too much friction and chafe.
Bob
Old 06-09-2008
funsailthekeys is on a distinguished road
Tank replacement
Just a thought on replacing fuel tanks. I've found that replacement plastic tanks can be removed later for cleaning. You can glass a section in under the floor in the spider area for a built in tank( the least expensive). You are probably not going to use as much fuel as you think so a smaller tank might work even better. good luck. I didn't discuss aluminum tanks as they are too problematic.
Old 06-09-2008
The problem with bladders for sailboats is that the diesel requires a return line. Getting the bladder positioned and properly supported and protected from chafe is generally a PITA. A hard tank, made of cross-linked HDPE, is probably a better way to go with less headaches in the long run. Plastic tanks need to be braced and supported as well, but not to the same degree as a bladder does.
Old 06-09-2008
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Funsail - why will he use less fuel than he thinks ? I don't understand that at all.
Ref the tanks - we have an issue where the old tanks are rotten and have to come out. This can be done but not easily so we will replace the two large tanks with three of even four small polyethylene. I'd not be happy to reduce the overall capacity however. When cruising, fuel supply is not always that reliable so I like to carry as much as possible without resorting to portable jerry cans.
Sd - HDPE ? High Density Polyethylene ?
Old 06-10-2008
Omatako's Avatar
Omatako will become famous soon enough
Whilst not advocating bladders for fuel (my preference is ali for fuel) if you're hell bent on them then the simplest way to take care of rub and chafe is to line the compartment with a piece of carpet (as long as the cavity doesn't get a lot of water in it). If the carpet is to be replaced down the line the bag can just be lifted when empty and a new piece stuck in.
Most bladders are easily mounted because they have eyelets from which they can be suspended.
My only rider is: Have you seen how far a leaked cupful of diesel can stretch? It is awe-inspiring.
Andre
Old 06-10-2008
TDW-
Correct fuzzy one.
Old 06-10-2008
Rockter will become famous soon enough
Sometimes the bladder solution is the only way of keeping your sanity.
Has anoyne ever looked at the fuel tank on a Union 36?
Has anyone ever tried to get the tank out?
Or a new one in?
I tell you, the only way to get a new one in there is to weld the new tank in situ and you'll burn the boat down if you try, assuming you don't die of welding fumes before that.
The Union 36 did not design the fuel tank, or water tank for maintainence.
If the fuel tank leaks again, I will cut the top off it, grind down the angles, line it with carpet or neoprene, and put a big bladder in there.
I might keep my sanity then.
I wish I had modular tanks as described. I don't though, and bladders are likely to be my only move if leaks develop.
Old 06-10-2008
timday5 is on a distinguished road
Polyethylene gas tanks - any problems/
I'm considering installing a Moeller cross-linked polyethylene gas tank ( sorry the site won't let me post the link - see moellermarine dot com/aftermarket/fuel_storage_tanks/permanent_tanks/). Sounds like a few of you have installed these. Anyone have any bad experiences with polyethylene versus aluminum gas tanks? The advice I've received so far seems to favor aluminum, but I don't understand why.
Old 06-10-2008
1970Columbia34's Avatar
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
I would remove the old one and make a new tank out of satinless steel. This way its a perfect fit and you don't lose any capacity. Here is ours we did 2 years ago. When we started this project it in the back of my mind to "do it right= do it one time" the stainless will be good for life.
Scott
Replacing my fuel tank this Spring, and need your sage advice. ChicagoNewport27 Gear & Maintenance 12 06-04-2008 07:39 PM
Fuel tank Replacement samchristo Pacific Seacraft 3 08-06-2007 09:37 PM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 07:00 PM
