atomic 4 thermostat question - Page 2 - SailNet Community
post #11 of 21 Old 06-09-2008
chtaylor's Avatar
A while ago, I found that the previous owner had taken out the thermostat. I installed one of Moyer's conversion kits and my engine runs at about 140 - 150 degrees at cruising RPM. You may want to get the kit so that if you have problems in the future you can use a normal automobole type thermostat.
Charles
chtaylor is offline
post #12 of 21 Old 06-09-2008 Thread Starter
cap'n chronic
cnc33voodoo's Avatar
i thought of that but you still have to use their t-stat.
cnc33voodoo is offline
post #13 of 21 Old 06-09-2008
Maybe I stand corrected. Perhaps the lack of thermostat will make it run hotter???!!! On the Atomic, perhaps a stuck thermostat will overcool the motor???
On the Volvo MD17C it will run cooler.
Pls be careful. Watch that temperature.
Rockter is offline
post #14 of 21 Old 06-09-2008
1975 Newport 28
jaschrumpf's Avatar
Originally Posted by cnc33voodoo View Post
im pretty sure i need to have one in as its not getting to operating temperature so its giving me stalling issues if i shut off the choke.
the engine runs fine but if the engine is idling and i shut the choke off it runs for 5-10 minutes then stalls.if i restart it stalls untill i pull the choke back on.
ive had this issue on cerbureted cars a couple times due to stuck open t-stats.
I have a Newport 28 with an A4 in it, and last week while testing the t-stat I ran it for 40 minutes at full throttle (in gear, tied up to the dock) with engine temps sitting at 135 deg F. with no choking problems. If you are suffering fuel shutdowns after 5-10 minutes of opening up the choke, you probably have carb issues. The A4 will run just fine at those low temps, but the incomplete combustion will foul the plugs faster than normal.
For a short-term fix, you might try "calibrating" a pair of vice grips to partially close the line from the pump to the t-fitting on the water jacket side. That would reduce the amount of water going into the cooling jacket and would let the engine get to a higher operating temperature.
If you haven't posted your problem to the Moyer Marine forums yet, you should do so. There is a wealth of knowledge there, and Don Moyer is the patron saint of A4s. I'm sure you'll get many more suggestions to help solve your problem until you can get the much less expensive Moyer t-stat delivered.
Good luck!
jaschrumpf is offline
post #15 of 21 Old 06-09-2008 Thread Starter
cap'n chronic
im sure the problem is the operating temps.btw,its only at ilde after i shut the choke off before i go anywhere.when its running in gear all is well.
i dont know if i would ever run my engine at full throttle,in gear,at the dock,for 40 minutes.
that would probably get me kicked out of the marina.
its like starting your engine cold without the choke.it will stall untill you let it run with the choke long enough to get the engine warm enough to push the choke off.
well, at least ill know when i replace the parts.
i ordered the parts earlier from marineparts.com
its an oem holley t-stat with gasket for 130 plus shipping.
problem is im a child at heart and need everything now now now
so taxes and overnight shipping was $230 total.
still a rip off as far as im concerned but better than the local guy who's greed lost him a sale.
now maybe i can sail this boat instead of fixing it for once.
thanks.
post #16 of 21 Old 06-09-2008
timebandit's Avatar
Before I paid that much for a thermostat I would take the dementions to a auto part store like NAPA that has books with all the part numbers and the measurements.
I have been doing this with motorcycles for years.
If you can try to get one that sticks open when it goes bad.
Rick
timebandit is offline
post #17 of 21 Old 06-09-2008 Thread Starter
cap'n chronic
Rick
i looked thru rows and rows of t-stats.
ive been to all local parts suppliers(napa,uap,parts source,carquest,canadian tire),parts stores,freinds shops etc.
i spent hours on the net and phone, called every shop in ontario that deals with a4's or universal engines and found nothing.
there were 7 or 8 shops that are known for repiaring/selling parts for these engines and they have no stock.
i even called the manufacturer/distributer in toronto and vancouver-backordered.
there is no t-stat that has the same design.a few were close but not close enough.
the a4 has a specific t-stat.they have a flat top that rests against the flange housing where a bypass flows thru.the head is also very shallow for most standard sizes so if they fit on one end, they didnt on the other.
i was even looking at ways where i could install a new flange that would accept an automotive t-stat but nothing fit perfect and i wasnt into doing a hack job to save a couple bucks.
i was sick to my stomach with this whole thing.especially after i spent all of last week running around to fix a furling system with equally challenging parts support.
im just itching to go sailing.
post #18 of 21 Old 06-10-2008
Valiente's Avatar
im in toronto,ontario,canada.
found a t-stat housing flange.$47.perfect.
no-go on the t-stat.
check this-the distributor for universal in ontario (westerbeke) sells the part for $150.
they are on back order.
in fact, everyone sells them for $150 in my area,but they all order from the distributor above mentioned as does the marine store that wants to grease me for $280.
im probably going to have to eat it and pay the $280.
my freinds took time off work so i just want everything together so i dont let everyone down.
it will cost more in beer and excuses.
The thermostat is called a Holley and comes in two temp. ranges: 140 F for sea water (not applicable) and 180F for fresh water. I assume you have raw water cooling and not a separate cooling circuit.
I will tell you now that the 180F are preferable because an Atomic 4 runs cleanest and best at that temperature. 140F is a compromise due to the precipitation of salts in sea water in the ocean-going Atomic 4s. I will also tell you that a working 180F thermostat is hard to find these days and people like me hoard 'em.
Sometimes the temp is not marked on the thermostat. You get a beer making thermometer (range 100-212F) and pour hot water on the thing in a glass until you see it open. If that's circa 180F, you are good to go.
See here: Atomic 4 Updates
"Volvo #875781-7 thermostat replaces Holley thermostat on newer engines if you put it on top of a 1/8" thick spacer (in the shape of the gasket)."
You can talk to Paul at Eastern Marine on Leslie St. about this. It's a quick fix if they are in stock.
If push comes to shove, Lake Ontario is still only 12 C/53 F. You could simply put in a brass ballcock in the 1/2 inch rad hose between the side water passage plate and the thermostat housing, put it at full open, and run the engine under load for 15 minutes. If it stays at 120F, start shutting the ball valve until it gets to 170F-180F (I assume your water temp. sensor is working).
A lot of people do this, particularly where the problem isn't overheating, but "underheating".
If you are really pressed, maybe I can loan you a spare if you leave some kind of ransom but the path of least resistance is four hose clamps and a two-barbed 1/2 inch Home Depot ball ****...and some patience.
Valiente is offline
post #19 of 21 Old 06-10-2008
Valiente's Avatar
Oops, I guess you've moved on this already.
Valiente is offline
post #20 of 21 Old 06-10-2008 Thread Starter
cap'n chronic
no, thank you.im going to try that idea of adding a ball vavle to the 1/2 hose.
i never thought of that.
unfortunately i ordered a 140deg t-stat,but i was told this is oem?
one way or the other i can use that idea to regulate it.
thanks.
Atomic Is No Bomb sailnaway Atomic 4 9 10-21-2011 12:43 PM
Thermostat for Atomic IV owlmtn Gear & Maintenance 7 07-07-2010 07:06 AM
Oven Thermostat rogernewell Gear & Maintenance 3 11-24-2006 08:25 PM
Atomic 4 Woes Mark Matthews Gear and Maintenance Articles 0 10-03-2001 08:00 PM
Atomic 4 Question Ericsson29 Gear & Maintenance 7 09-12-2001 01:40 PM
