06-09-2008
You definitely can run the engine without the thermostat, but be careful. My Universal 5411 diesel is raw-water cooled like the Atomic Four, in fact I think it uses the same 140 degree thermostat. I once tried to run without one and it overheated. Seems that as the water heats up, the thermostat closes and forces more of the recirculating water out the exhaust. Without the restriction of the thermostat, the water just recirculates and gets hotter and hotter! Clamping the hose returning the water from the thermostat back to pump fixes the problem. In fact some A4 owners just put a valve in that line and control the temp manually.
