Old 06-09-2008
blakehanks is on a distinguished road
Smile spreader repair
Just put up mast on my 1994, hunter 26 and looked up at the end and saw that one of my spreaders was bent down, I have the boat in the slip now and am wondering how to replace either the spreader connector or can the spreader be bent back up, The tension on my one shroud is limp. Can I repair this at the slip, if so how difficult. Just a rookie from Idaho looking for some help. Thanks!!!!
Old 06-09-2008
cnc33voodoo's Avatar
cap'n chronic
cnc33voodoo is on a distinguished road
can you take a pic to see exactly whats going on?
the question is why is it bent?
Old 06-09-2008
spreader
Im at home now, 2 hours from lake, only thing i can think of is that my flag rope caught on the side of rail and was pulled tight as I was raising mast. I had to slip it off a hook that it caught on but was able to do it by hand.
Old 06-09-2008
cap'n chronic
i just checked online to see how the spreader connects to the shroud and couldnt find a clear pic.
youll likely have to drop the mast again to remove the spreader.
Old 06-10-2008
Unless the spreader is damaged, you may be able to just move the spreader back into the proper position. It could have just been moved. Without seeing a high-resolution photo of the issue, can't really say much. Most spreaders will move through a range of motion without serious problems, and yours may just need to be moved back into the proper position.
Old 06-10-2008
spreader
Thanks for the help. Im heading bback to the lake this weekend and will get a better look.
Old 06-10-2008
Thanks guys, Im heading up this wekend . Will drop the mast and take a look. Happy sailing.
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 08:00 PM
Sail Repair 101 Don Casey Seamanship Articles 0 03-10-2003 07:00 PM
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
Sail Repair at Night, Sailor's Delight, Part Two Don Casey Seamanship Articles 0 03-16-1999 07:00 PM
