Old 06-10-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Dutchman Flaking System
[couldn't delete - found answer on the manufacturers website, disregard below]
We have had a pretty nasty storm come through this afternoon. When I got to the boat after the marina call to double check the fender status as one had popped out and hull went a little bouncy bouncy - I discovered that the topping lift didn't seem right as the boom was on the bimini.
Closer inspection revealed that both sides of the most forward Dutchman guide lines had popped off. I imagine it would of happened sooner or later as there was evidence of chaffing pretty much all along the top most parts of the plastic filament.
So question I ponder the experts ...Could I use that lite weight thin spectra line instead as a replacement? Any one have any experience with it and things I should be wary of?
-- Jody
S/V "
1983, Barberis Show 38! or
Old 06-10-2008
JOdy-
If you found the answer on the manufacturer's website, you could post what you found here...in case anyone else needs that info.
Old 06-10-2008
JohnRPollard's Avatar
Moderator
Yes, please post the answer. Enquiring minds (with similar chafe on their monofilament ) would like to know. Thanks.
Old 06-10-2008
artbyjody's Avatar
I did - I provided the documentation link But yes, one may use Spectra - or if they read the manual, you can get instructions on how to get a free replacement of those particular lines. The lines themselves can be purchased at any hardware / fishing store just do not use the weed waker variety. I am going to use the spectra myself for longevity reasons.
-- Jody
S/V "
Old 06-11-2008
artbyjody's Avatar
I ended up replacing the line with Marlow VC type. Its the same width, its higher breakage, and if it shreds its 12 bucks for 50 feet of it. And its colored..
The drawbacks to it is that it as not as knot resistant as the filament used stock with it. But, for the cost - I am willing to see how it works out...
-- Jody
S/V "
Old 06-11-2008
andermark is on a distinguished road
Hi Jodi,
You posts on the dutchman were very helpful.
By the way, I noticed you have a Barberis Show 38. I am considering buying a 1983 Barberis Show 34. Do you have any suggestions, information, cautions, links? I am having a difficult time getting much information about these boats.
Thanks, Mark
Old 06-11-2008
artbyjody's Avatar
Originally Posted by andermark View Post
Hi Jodi,
Thanks, Mark
Thanks
here is a link to my post-purchase review on the Baberis: http://www.sailnet.com/forums/buying...tml#post327670
-- Jody
S/V "
Dutchman Sail Flaking System Problem Trescool Gear & Maintenance 4 07-29-2007 01:41 AM
Refrigeration—Part II Selecting a System Tom Wood Gear and Maintenance Articles 0 05-19-2003 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Dutchman vs. Lazy Jacks Pros and Cons SailNet Gear and Maintenance Articles 0 04-05-2001 08:00 PM
Lazy-Jack or Dutchman System Dan Dickison Gear and Maintenance Articles 0 01-17-2001 07:00 PM
