Blogs
User Name
Old 06-20-2002
Variant_530 Variant_530 is offline
Variant_530 is on a distinguished road
Honda outboard problems
I have an 80s Honda 7.5 Horse power outboard with a peculiar problem.
The engine looses power and sputters with the cowling on. As soon as I release the cowling cover the engine perks right up.
I checked the exhaust pipe and there is no exhaust leak. I''ve tried tuning the carburetor and that doesn’t help. Can any body offer a suggestion to remedy this problem.
Thanks
Old 06-21-2002
mikehoyt mikehoyt is offline
mikehoyt is on a distinguished road
I have same engine and have not had that problem.
Recently took mine in to a dealer for servicing. Cost $60 (1 1/2 hours labour) to have carb cleaned, needles blown out, compression checked, valves adjusted, etc... Had to take it to a motorcycle dealer (go figure). Might be worth a try.
I would check to see if the cowling is pinching or touching anything. Maybe you are touching a spark plug wire, fuel line, or something? I am sure you checked this out.
Another common fix for these engines is brand new plugs. I am sure you probably already tried that. Use NKG I think DH5HS?
Good luck!
Mike
Old 07-08-2002
Hobgoblin Hobgoblin is offline
Hobgoblin is on a distinguished road
There''s no doubt your problem''s the cowling.
Check for chafing inside(fuellines,vacuumlines from carb., sparkplug-leads,etc), if not, there is a venthole somewhere, to provide intake-air ,this might be clogged.
Succes.
Display Modes
vB code is On
Outboard: Buying, Type & Fitting omega001 Gear & Maintenance 11 11-10-2006 10:09 AM
Outboard motor controls waltzingmatilda Gear & Maintenance 0 07-13-2003 12:32 PM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
Honda Outboard Motor xenetia Gear & Maintenance 0 04-19-2001 02:50 PM
Honda Outboard GGartin Gear & Maintenance 0 01-14-2001 05:14 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
