Blogs
User Name
  #21 (permalink)
Old 06-12-2008
rheaton rheaton is offline
rheaton is on a distinguished road
A good place to get this would be a RV / camper store. They use it to seal their windows.
  #22 (permalink)
Old 06-12-2008
Freesail99's Avatar
Freesail99 Freesail99 is offline
Freesail99 will become famous soon enough
Yep it is and I said that in post number 4.
S/V Scheherazade
  #23 (permalink)
Old 06-12-2008
xort xort is offline
Getting closer!!!
xort has a spectacular aura aboutxort has a spectacular aura aboutxort has a spectacular aura about
Speaking of windows, any thoughts on using this on plexi or lexan windows as a sealant?
Sponsored Ad
  #24 (permalink)
Old 06-12-2008
Freesail99's Avatar
There is another thread on using butyl tape on ports. I did it a few weekends ago myself, on my boat. I'll see if I can find the thread.
S/V Scheherazade
  #25 (permalink)
Old 06-12-2008
Freesail99's Avatar
Xort, here is the thread.
http://www.sailnet.com/forums/gear-m...ortlights.html
S/V Scheherazade
  #26 (permalink)
Old 06-12-2008
Maine Sail's Avatar
Maine Sail Maine Sail is offline
Maine Sail is a jewel in the roughMaine Sail is a jewel in the roughMaine Sail is a jewel in the rough
Xort,
Unless the ports are also screwed or through bolted I personally would not use butyl. Butyl has very little to no adhesion but it is very sticky and flexes and stretches LOTS to accommodate any movement well. If your ports are of the acrylic type that are non opening, and with no frame, similar to what Catalina uses for their non opening ports, you should use Dow 795. It's what Catalina, and I have heard Hunter, use at the factory for installing the acrylic non screwed in ports. It's an adhesive silicone made specifically for structural window glazing and works well for the application.
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
Our Sailing Photo Galleries
  #27 (permalink)
Old 06-13-2008
Rockter Rockter is offline
Rockter will become famous soon enough
Neat work. Good finish.
  #28 (permalink)
Old 06-17-2008
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Moderator
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Halekai,
I noticed that you did not seal the end grain of the core with epoxy prior to bedding with the butyl tape. Is this because you are confident enough in the bedding properties of butyl tape?
If you were installing something like a genoa track (in the manner you described above), would you also forego the epoxy and just use the butyl tape even if it was in a cored area? Thanks very much for your suggestions.
  #29 (permalink)
Old 06-17-2008
Maine Sail's Avatar
Originally Posted by JohnRPollard View Post
Halekai,
John,
I'm very confident in butyl but if doing a genny track in a cored section I would "pot" the holes! My entire boat was bedded with butyl at the factory 29 years ago. The cleats I removed were BONE dry and subject to some high loads. I did not pot the hole because:
#1 I countersunk them to create an o-ring something that was NOT there for 29 years and they still did not leak!
#2 These machine screws will see NO movement or load and are merely decorative to hide the existing holes
#3 It's summer and I'd rather be sailing than potting holes unnecessarily.
My genny track goes through a solid UNCORED section of the deck, as they all should, and even after 29 years with NO countersinking & butyl tape they still don't leak ONE drop of water.
The countersinking or slight beveling of the fastener holes only further guarantees dry non leaking decks. Still any high load item, through a core, should be potted & countersunk slightly..... My screws are no load, no movement...
______
-Maine Sail
Casco Bay, ME
Boat - CS-36T
  #30 (permalink)
Old 06-17-2008
SVCarolena's Avatar
SVCarolena SVCarolena is offline
Pearson 303
SVCarolena is on a distinguished road
"#7 Countersink each hole very slightly using a countersink and REVERSE on your drill. Using forward will make the hole way to big if you are not careful. Contrary to popular belief countersinks work wonderfully, for detail work in fiberglass, in reverse and you won't chew through the deck in.002 seconds while having an ADHD moment.."
Another option that I use when countersinking in glass is to use a handheld countersink. They are very inexpensive and eliminate the "oops" potential.
vB code is On
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Installing Deck Hardware Don Casey Miscellaneous 0 03-30-2003 08:00 PM
Drilling and Filling Holes in Your Boat Sue & Larry Gear and Maintenance Articles 0 03-11-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
Page generated in 0.5512 seconds (66.27% PHP - 33.73% MySQL) with 15 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
