06-13-2008
Warantee? The boat is over 20 years old. The water system has been in place as standard equipment since new. I'm sure the water pump is not original but it's not new. The rebuild kit is new and didn't get the job done. BUT, it did work at one time. It's not lift and it's not pressure.
How simple can I make this...when the pump works properly, you CAN feel the suction. When it doesn't work right, you can't feel any suction. The motor runs and has torque but the pump does not pump.
Since you all don't seem to have specific experience rebuilding Sureflo pumps, I suggest you pass on giving more advice.
Thanks
