06-13-2008
"Fairhaven" Formosa 41
Originally Posted by SEMIJim
Note my self-proclaimed "nautical newbie" status and consider my comments in that light  .
ISTM "has seen better days" and the too-tight leech is an unusual complaint? I had thought that when sails aged, became "blown," the problem was generally one of not being able to get the leech tight enough? It hadn't occurred to me the problem was the sail might not have been designed for your boat, as Faster suggests.
In general terms: Drawing a line from mid-way up the luff, through the clew, will show you a reasonable starting-point for your genoa cars. Then you adjust from there, based on whether you need more twist at the top (move cars back) or less (move cars forward). This is determined by observing sail shape and telltales, and behaviour of the helm. It will change depending on tack and wind strength. From the starting point, you should have adequate track, both fore and aft, for tuning. Otherwise, as Faster suggests, perhaps that sail wasn't really designed for your boat?
How does the sail's luff look? Do you have, can you get, adequate forestay and halyard tension?
Jim
Depending on sail construction and design the leech, luff and foot are often the most reinforced areas and are made of multiple layers of cloth that may be entirely different from the working part of the sail. As the Dacron in the central part of the sail stretches the "edges" of the sail don't stretch as much. This means that when the sheet is led properly, the halyard is tightened appropriately and the sail is full it is tight on all edges but has a deep belly in the middle. When this happens the sail is past it's useful life for all points of wind forward of the beam.
If it's just the leech that's tight perhaps you have a leech line that could be loosened? Perhaps the sheet should be led further aft? I like to experiment with sail shape on a moderate wind day by going forward and manually pulling on the sheet or clew to see how the shape looks when there is more downward sheet force (car forward) or more aft pull (car aft).
Of course if you're just dying to buy a new sail than I will proclaim, with great confidence, that your sail is toast and you should replace it immediately.
The bad news is that you have to go sailing again to figure all this out...
Medsailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
