Old 06-13-2008
mwrohde is on a distinguished road
Head Plumbing
I am giving some thought to replacing the holding tank (bag, in my case) and plumbing on my boat. I'm aware that the recommended replacement hose is OdorSafe, but at $8 a foot . . .
Why wouldn't I, couldn't I, plumb the head to holding tank with rigid PVC? Is there a reason other than pulling flexible plumbing is easier?
Thanks,
Matt
Old 06-13-2008
Joel73's Avatar
1987 Pearson 27
Joel73 has a spectacular aura about Joel73 has a spectacular aura about Joel73 has a spectacular aura about
I would think that rigid PVC would crack over time with the stress of being underway... but maybe it could work for your set-up. I will be replacing ours soon and i expect i'll use flex.
8/ft?????
"Unthinking respect for authority is the greatest enemy of truth." - Albert Einstein
Old 06-13-2008
RAGTIMEDON's Avatar
RAGTIMEDON is on a distinguished road
The vibration and flexing of the boat will cause the pvc glue joints to crack. You can buy cheaper flexible hose, but the good stuff is 8 bucks a foot! Is your nose worth 8 bucks a foot? Or is your wife's nose worth 8 bucks a foot?
Don
1980 Endeavour 37 sloop, currently in the Mississippi near St Louis
Old 06-13-2008
SVCarolena's Avatar
Pearson 303
SVCarolena is on a distinguished road
8/ft?????
In addition, PVC generally requires a number of somewhat sharp turns (i.e., 45degree elbows) to get where it is going. This makes it hard to install and creates potential blockage problems. Try to design a system with the shortest runs possible, which will reduce the amount of hose needed and the amount of water used, buy the good stuff, and then you will be good to go for a number of years. What type of boat are you converting? I'm still working out the best solution to replace the bladder system on my P303.
Old 06-13-2008
The main difficulty with rigid PVC pipe is as Joel points out, the fact that it tends to crack. It has been used with some success on some boats I've seen, at least for the longer static runs, and prevents the issues with odor permeating the hoses.
One thing about the SeaLand OdorSafe hose is that it will probably out last the cheaper stuff... one major source of hose odors is the hoses becoming permeated with the sewage and then the hoses themselves become a source of odor.
Old 06-13-2008
Traveling Light is on a distinguished road
PVC Usage for Holding TanK Plumbing
I used PVC for straight runs and flexible hose for not so straight portions. For the angles I used a black flexible plumbing pipe (I can't recall its name, maybe Fenco, but I purchased at HD). It has worked great and I have had it in place for four seasons - this is the start of the fifth. The elbow sections are connected to the PVC with worm type hose clamps (SS of course). Another owner of a boat like mine - Pearson 28-1 - suggested this approach and pointed out that it makes it easy to get to a clog, has not happended yet, if needed. The PVC has not cracked and there is no smell. I believe the flexible joints eliminate potential stress which would cause cracking.
Old 06-13-2008
Thanks for the replies, guys. Good information.
The follow up question is the bag that I've currently got in the boat (Cal 3-37) - it's a 12 gallon black bladder that says it's for diesel and holding. Is this likely to be permeated and causing smell as well, or is it something that if it's not leaking then it's still ok?
Old 06-13-2008
If hoses can permeate, so can the bag. Easy way to check...Get a cloth, wet it with near boiling water, drape it over the bag or hose, wait a few minutes, pick up the cloth, sniff. If it smells like sewage, the bag/hose has permeated.
vacuum break in head plumbing Artwerke Gear & Maintenance 3 01-18-2006 02:13 AM
Boat Plumbing Inspection Tom Wood Gear and Maintenance Articles 0 02-17-2004 07:00 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
