06-13-2008
seeker
That is probably your only choice EO but I see a potential trap there, in that when you re-drill and tap getting the tap to just clean out the threads in the nut and not try to re-cut the threads between pitches might be a chore. IMHO you might be better off to run a well waxed, or greased screw down the hole into the nut until the epoxy cures, then run it out and run a tap down the hole to be sure you get full thread depth in the hole. Hex head would make the job of cracking it free easier but you may have difficulty locating a full thread hex head cap screw. If you have a hard time cracking the screw free, give it a sharp blow straight down with a fairly heavy hammer, better yet, smack the end of the screw driver with a soft blow hammer, or try heating it with a soldering copper or gun.
This technique would have the added benefit of having threads the full depth of the hole with the stainless nut at or near the bottom. It is quite surprising how much hold fully cured , thickened epoxy has on a coarse threaded hole, and in fact the "cast in" nut would be functioning more as a safety than a primary fastener.
Feetup
