06-13-2008
Best Looking Moderator
My guess is that it is probably a 3", but it is more complicated than that (isn't it always??). It depends on the length of run, elbow, number of turns, the muffeler, the rise, and the ehaust T-Hull. It is complicated.
It is a matter of back pressure. Too small of a hose will cause excessive back pressure, causing heat in the rear cylinders, causing carbon build up, then scoring, compression loss, then failure. That is the process.
You can contact one of a couple of marine exhaust comapnies (there is a good one in FL... but do not remember their name) to discuss their suggestions. Or, you can try running with what you have a taking a measurement. The exhaust pressure should probably be around 2.5 psi at WOT (Wide Open Throttle). Check with MFG on their specs. THey will know this. If it exceeds, say, 3... you will have problems if you run the engine for long periods.
Checking the pressure is easy and can be done with simple parts bought from a auto parts store. Effectively, you get a needle with a presure gauge and jam it in at idle, cruise, and WOT. Take the measurement. You then will need to plug the hole. If memory serves correct, I used a HT Silicon, covered that with a piece of HT Exhaust hose, AND clamped that with a hose clamp.
Buy a CO indicator afterwards to make sure you do not have any leaks (you need one anyways... that should be ABYC IMHO).
Hope that helps.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
