06-14-2008
Heizir's got a very good point... was the backstay always too long??
As he points out, it may be caused by something that needs to be corrected, like a flexing cabin top, failing compression post, rotting bulkhead, etc. It could also be caused by the forestay chainplate elongating, although this is less likely IMHO. Have you checked the other chainplates and the compression post or bulkhead???
