Blogs
User Name
  #21 (permalink)
Old 07-13-2008
sailaway21 sailaway21 is offline
Owner, Green Bay Packers
sailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the roughsailaway21 is a jewel in the rough
I too went with an oil-based exterior trim paint and have been happy with the results on my boat. I wanted it glossy because, in my experience, the gloss tends to diminish over time and it reflects light well in notoriously under-lit boats. If you start with a satin finish it will be dimmer inside to begin with but, preferences vary.
Even Don Casey says you can get away with this cost-savings measure and as soule says, I've got a half gallon left over from a gallon that cost half what a quart of a marine paint would have cost me! and the advantage to that is that, should you need to do further coats, touch-up, or repaint you're not looking at another large budget expense and therefore more likely to do it.
The brain is merely a knot that keeps the spinal cord from unraveling.
  #22 (permalink)
Old 07-13-2008
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
BTW, the ISO he is talking about is the ISOCYANATE components of the two-part paints. This is a CYANIDE-based compound and faily toxic.
Originally Posted by Zephyr88 View Post
DO NOT USE TWO PART PAINTS ON YOUR INTERIOR.
The iso's in the catalyst WILL harm you.
I've spoken to a spray painter now a crab fisherman, also to another ex-spray painter now an auto parts salesman. They both had horror stories of people using two part paints (this includes two part varnishes) in enclosed areas without air feed respirators (normal respirators do not stop iso' being absorbed by the lungs). It also turns out you absorb more iso's through your skin than what you breath in.
I would suggest using a good enamel paint, remember the white enamels will not keep their bright white. Read the can on brightsides by international.
If its cool (less than 20 C) don't use more than 5% thinners, use the propriotory thinners as mineral turps contains too many impurities and will muddy the finish.
Make sure you have good air flow through the cabin, set up a large fan in the companionway and open all of the hatches and ports. A good quality respirator will do a good job when using single part paints.
Good painting
Zephyr
If you're new to the Sailnet Forums... please read this POST.
Display Modes
vB code is On
Life in the fast lane, well for one day at least... Lancer28 Learning to Sail 8 11-27-2007 11:36 PM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 07:43 PM
The Joys and Pitfalls of Buying a New Boat - Part 1 Lin & Larry Pardey Buying a Boat Articles 2 11-16-2006 09:51 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 09:00 PM
buying first boat jerrycooper14 Buying a Boat 21 04-23-2002 03:15 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
