Hi everyone..
I have a Tanzer 22 .. Anyways, my friend and I had taking to using the jib winches, located just ahead of the bulkhead on either side of the companionway to hoist the halyards (which are running through a couple blocks on the mast) when we fly the genoa, as it has it's own set of winches on the rails..
Apparently this was a BAD idea ..
.. While trying to pull the main all the way up (too bad the outhaul was tight which is why it wouldn't go that final few inches .. live and learn!) the damned winch tore right out of the hull!!
So the winch (barlow 15) was held in w/ 6 one inch screws directly into the fiberglass.. It looks like the screws all stripped right out ( a couple of them bent) and the adhesive that was applied to the bottom of the winch failed too.. anywas suffice to say the whole thing came off in my hand and I have 6 little holes in my hull now
Obvously I want to put this winch back on, in the same position (and not use it for the halyards anymore.. lesson learned! ) ..
I have removed it, dissassembled and cleaned it and cleaned the hull with acetone (and taped over the holes for now so the rainwater doesn't get in)
What's the best way to go about filling the holes and re-installing.. I had a few thoughts (am woefully inexperienced working with fiberglass so some advice is what i'm looknig for)
anyways MY ideas for repair:
1. drill out the holes a bit to clean them, fill with epoxy from a syringe of some kind and once it dries drill the screws back into that, with some adhesive under the winch .. yes / no bad idea good idea? or should the new holes be off center from the old holes?
2. use the existing holes, just buy some bigger screws that fit the winch that will bite what's already there and a bit deeper (there is clearance and they won't poke inside the cabin)
I was surprised that the winch was not secured to some kind of plate.. I didn't realize this things just screwed into the FG or I would have not used them for the halywards in the first place..
As an aside, got caught in middle of the lake during a 50 kt blow with hail that came in out of nowhere the same days.. yikes! sails down, motor into the wind it was scary but we were fine..
