Old 06-16-2008
johnr
jr438234606 is on a distinguished road
Exhaust siphon break
Hi all. I'm still trying to figure out this new-fangled Yanmar 4JH4AE. I'm working on the exhaust system and need to know where to install the siphon break. I'm thinking that these two large nuts are meant to be tapped into for just that purpose. If anyone has this engine, let me know if I am thinking correctly. My users manual doesn't identify the purpose of these nuts.
Thanks!
Old 06-16-2008
Sea Slacker
brak is on a distinguished road
I jave an older 4JH3E which looks just like this one. I am not sure there is a siphon break though. One of these nuts is tapped for water connection that is split in two - one part goes to dripless shaft seal, another into water muffler - not sure what the purpose of that is.
Old 06-17-2008
johnr
Do you see a siphon break of any sort installed at you engine/exhaust?
Old 06-17-2008
Sea Slacker
No, not that I know of. The way it is installed there is a short exhaust hose (downward) to the muffler, then another short downward run followed by 90 degree elbow and a long run of exhaust hose to the stern. At the stern there is an inverted U loop (metal) that goes above water line, then a kind of a rubber flapper valve(not sure, left over from previous engine) that connects to exhaust thruhull.
That's it - no siphon breaks as far as I can see.
Old 06-17-2008
funsailthekeys is on a distinguished road
Is the engine below the water line?
Old 06-17-2008
We have several Yanmars that have the break between the heat exchanger exhaust and the Exhaust riser elbow. Seems easy enough to just replace the short black hose with the break. Hope this helps.
Old 06-17-2008
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Jr, mine was installed where water intake was cool, between engine water pump and heat exchanger, not at the exhaust, wich I think will have same breaker effect/protection. I believe the most concern has to do with your waterlock, as returning water from exhaust (when you turn engine off) could find its way back to the raiser elbow. Rule says you should move it up from the water level as much as rasonable (Volvo says 40 inch) and center it as much as possible (for when boat is heeling).
Old 06-17-2008
Rockter will become famous soon enough
If the motor is below the water line, it really must have a siphon break.
It really must.
They are not expensive.
It must go between the exhaust coolant entry point and the heat exchanger on this motor. On my olde raw water cooled motor, it is between the exhaust coolant entry point and the (wet) exhaust manifold.
Old 06-17-2008
johnr
Fun, the more I study it, the more I realize you are correct. The little short hose could easily be replaced with a length of hose with the siphon break at the top. I still don't know what the nuts/ports are for though...
Old 06-17-2008
There are several applications for the exhaust elbow so there are a few extra nuts and bolts. Yanmar being the wise entity they are try to use the same parts on as many versions of engine that they can.
1967 Irwin 37 cc with exhaust problem Irwin37mkIV Irwin 5 08-02-2007 07:03 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
Diesel Exhaust Systems Sue & Larry Gear and Maintenance Articles 0 11-07-2001 07:00 PM
Anti-Siphoning Exhaust Sue & Larry Gear and Maintenance Articles 0 10-17-2001 08:00 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 06:55 PM
