06-17-2008
The problem with foam cores, like Divinylcell and Airex, is that they can allow water to migrate long distances, and delaminate rather large areas of composite after relatively little water intrusion, especially if the bonding between the fiberglass skins and the core was not done properly.
Are you sure that you've actually sealed the opening that is feeding the galley opening??
